Pixel - Signal dropping (Update: Google Knows)
For those of us not having signal drops, it seems like it must only occur under a specific enough set of conditions that a lot of us just never encounter it. I just checked and I'm showing LTE band 13 while sitting at work. From what I've read, the issue appears most often on band 4. So it's quite possible that I've yet to go anywhere with band 4 signal.
True.. That could be it. I use an app (top left) that always shows my band / dBm so I can easily see my true signal strength.
Do we know what those specific set of conditions are?
Assessing my risk here.
Specifically... Pretty much drops any phone call made using the network. Random signal drop. Zero signal at home and no transition into 3G at all
If you are doing anything that requires voice and data at the same time you get disconnected from your call
Can you elaborate on this more? Is this due to the issue or are you saying in general? Also what carrier do you have / does VoLTE work?
not sure about that, but makes me wonder with my issues why nobody has had me do that stuff?
Dunno. I am not an owner (yet) and was digging to see if I could find anything. That was pretty much all I could find. *shrug*
I'm on Verizon but read a lot that it might not be carrier related alot of Nexus users said ever since 7.1 was installed on their phones with various carriers it's all happening to them too. At this point nothing is for certain but it has been happening to me and I'm on my second phone now . Dropped calls no light connectivity start off with one bar get a text while on a call and nothing but disconnects . Who knows at this point but tons of readings online about all of it
I'm also on Verizon and having constant issues.
Maybe you guys can borrow a sim from another carrier and see if you have the same problem? It seems it might be possible to test if this is happening all the time and you know some of the conditions under which it happens.
I've had enough of pixel dropping service. My service today dropped in the middle of listening to a voicemail, waited 30 seconds signal was back on. Then later on went to text somebody, "can't send no service", waited 60 seconds signal was back. Called Google, and said this is my last call to you folks, if you can't tell me what Google is doing about this service dropping, I'm trading my phone in. Put me on hold, came back and pretty much said Google believes the problem is 7.1 nougat, and their trying to figure it out. He said "it's like being in war on the front lines, you get all the bullets". I have no clue what that has to do with my service dropping. Anyway I put my sim card into another phone, and service is back to normal. Google totally dropped the ball, I thought Samsung had a reason to be embarrassed, Google should be even more embarrassed at the pixel not even working as a phone.
Wow good thing I held off on getting the Pixel.
Layananbukablokirbni
