Please Help - Alarm Clock Gone
Wait Wait!!! Don't reset!
I ran into the same problem, it was very frustrating.
I found my solution by installing Simi Clock Widget, which is pretty customizable and allows you to launch apps by tapping different places on the widget. I took a shot in the dark and linked a tap location on Simi Clock to the stock HTC clock app and it worked! Afterward, the tap from my regular clock started working also.
Good luck! I hope you don't have to reset in the future.
Reactions: Gatchaman2025
Thanks! Installing this has made my stock HTC clock app return! It has been gone for months!
How do you tag it to your HTC Clock? I opened up the launch options but the clock is not an option to link it to.
Just an FYI for anone who's interested... I also found that I can still access the clock through Folder Organizer even though the Clock app was completely missing from my phone. I was able to see it in the list of apps in FO, and then I was able to put it into one of my FO folders and I can access through there or through a FO app shortcut with no issues. Just an FYI for anone who's interested...
I tried to search for my clock through manage applications because it was not showing up in my App list. Both Clock and Clock Widget show a size of 0.00B. Is that why it does not show up on my App listing? What do people's size say whose widget works. Is there a way to get mine back?
I actually just installed the program. I did not open it, I just clicked on my HTC clock and it worked. I'm not even using the progam I installed.
I would be so absolutely thrilled if I did not have to reset my phone to get the alarm clock back. I accidentally had my phone on in my pocket and I think it must have been something I did that just magically got rid of the alarm clock function. I loved it! It was the best. Now, I have downloaded the SiMi clock, but can't seem to understand what you meant by linking to different apps. I can't seem to do that at all. Could you give me lots more details about this? I would be so, So grateful!!!
I have been using the alarm clock on my Inc2 by just tapping on the clock on the main screen and going to the alarm clock. I went to go set it last night, I tapped on the clock, and nothing happened. I can't get to the alarm clock anymore.
Has anyone had this issue before and if so, how do you fix it? This is my only alarm clock, so I need to get this fixed as soon as possible.
Thanks in advance for your help!
At last I found the solusion!!!
All you need to do is add the widget alarm 4x1
And from this widget you can edit your existing alarms or setup new alarms
Frooti21
