Please help... My Galaxy S4 won't let me enable Wi-Fi
Re: Please help... My Galaxy S4 wo'nt let me enable Wi-Fi
Dear..i have a strange problem...i m using s4 i9515..wifi works perfectly but hotspot cant enable...whats the solution..? Kindly rep
So I had the same issue, I did not read everything single post here but here is my solution.
1 shutdown your phone
2 boot you phone in system recovery mode, to do so press the power and volume up button together until you see at the very top right corner a tiny blue line, then release the 2 buttons
3 with the volume down button go to "wipe cache partition", this will NOT delete any data on your phone !
4 select that option with the power button
5 reboot your phone with the first option of the menu "reboot system now"
It worked for me right away
Hope it helps, good luck to you
My S4 won't let me turn on Wi-Fi. I have tried every suggestions in this thread EXCEPT taking it apart to replace antenna and check for loose connection. Eventually I burned a Nandroid backup and flashed the stock ROM. It revives the Wi-Fi! Thus, I'm not sure if it is really related to stock vs. custom ROM as others have suggested. It's more like corrupted vs clean ROM. My OS is obviously corrupted. To prove the point, I restored my Nandroid copy and the problem returned. Since installing a clean copy of the OS and then re-installing/ configuring my 100+ app is too much pain, I am going to live without Wi-Fi. After all I have unlimited data plan with my carrier. I know backing up apps with Titanium backup and then restore can ease the pain, but my experience with TB hasn't been good in the past. Many apps just don't get restored properly.
If someone can suggest other system files to tweak other than those already mentioned, please post. Thanks
[update: A few hours later....
Others have mentioned if I delete this particular file under /data/misc/wifi, it will get regenerated. Well, it didn't on my phone. So I thought if I re-flash with a clean stock ROM, copy all files from this directory, then restore my Nandroid copy and then replace this directory with these clean files, it may fix the problem. After I re-flashed with a clean ROM, the WiFi still wouldn't turn on, but it did earlier! WTF!!!...
After checking under "About device", I noticed the baseband was from a different rev, I337MVLSGQB1, than the ROM I just re-flashed, I337MVLUGOH1. So Odin skip the baseband if the code on the device is newer? I then extracted the baseband, modem.bin, from the -OH1 ROM, and burned this file directly. Guess what? By having the baseband and the rest of the ROM both from the same rev, -OH1, my Wi-Fi is working again!
How do I explain the Wi-Fi was working too earlier? It's because I flashed the -QB1 ROM at that time. Thus, the baseband and the rest of the ROM was the same rev too at -QB1.
Now my baseband is back to the same rev as my Nandroid copy, -OH1. I restore my Nandroid copy and my Wi-Fi is working again!!! Huray!
I am not saying the baseband and the rest of the ROM always have to be from the same rev. Most custom ROM don't even come with the baseband. However, there is something funny about this I337MVLSGQB1 code. It is the same Android rev, 5.0.1, as the previous one, -OH1, issued 2 years earlier. Why did Samsung even bother? Well, they call it security fix. I don't know what exactly they fix, but I did observe a restriction. When I tried it last time, it prevented me from freezing bloatware using SD Maid. I couldn't tolerate it and went back to -OH1. I didn't know the baseband was still stuck at -QB1 and only the rest of the ROM went back to -OH1. Since I rarely use Wi-Fi, neither did I know this particular incompatibility also prevents the Wi-Fi from working!
In summary, make sure your baseband is not I337MVLSGQB1. If it is, then also make sure the rest of the ROM is also -QB1. If you don't like the "improvement" provided by -QB1, then downgrade from it, but make sure it is indeed downgraded. The -QB1 baseband may still be stuck in your device unless you specifically burn the modem.bin file from the rev you intend.
These are the stock ROM for the Canadian version of S4. If yours is AT&T, they will be different. However, if you come across a security fix issued in 2017 on Android 5.0.1, I am almost sure it will cause the same problem if you mix components of this rev with the previous one issued in 2015. The Canadian and AT&T versions of S4 are almost the same except the AT&T one has a locked bootloader, which prevents you from installing custom recovery and ROM. Avoid AT&T/Verizon phones at all cost if you are a hacker! My Canadian S4 is working great in the U.S. After all this AT&T protection (or limitation depends on how you see it) will not protect you when you mix two different versions of AT&T ROMs.
[Updated: one day later...
It turned out in addition to the Wi-Fi problem, which I solved yesterday by flashing modem.bin, I also had a hotspot problem. When I tethered my laptop through my S4, the connection would drop in a few seconds! After mucking around for half of a day, I finally realize although under About device it is showing I have the -OH1 baseband, modem.bin is only half of the story. There is another file, NON-HLOS.BIN I also have to flash! Now, I have a solid tethering connection!
GUYS I struggled with this wifi issue for 2 weeks and it was TORTURE and this method did not work for me because I couldn't turn on my tethering to start with. BUT I FINALLY FOUND MY FIX!! bAsIcaLLy, you have to turn off your power saving mode. IF ITS NOT SHOWN AS TURNED ON ALREADY, TURN IT ON. Then, type *#0011# into your dialler, click the drop down menu and select wifi, then hit OFF. Restart your phone, and the problem should be gone. Hope it works for u because not having wifi all day is tortureee ;)
For those that have this problem. I had the same thing so I removed the battery and after I put it back in and turned it on I could get my Wi-Fi to turn back on.
i have been rebooting ma phone doing literally anything wifi will turn on some times for only 2 or 3 mins and it doesn't work btw i just got ma phone from repair shop and still not working i wan't to turn off safe mode on ma wifi but i can't find the damn option :( on ma phone anything elsie i can do :(
Tiokujha
