Post Your Droid X Screens!!
Make sure you backup with Bootstrapper before you do anything and then follow Liberty instructions exactly...
Install:
make sure you have root and clockworks recovery installed
-boot into recovery via clockworks bootstrap
-select "wipe data/factory reset"
-select "Yes -- delete all data"
-go back "powerbutton"
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select LibertyX/2-X.X.zip
-reboot
Installing themes or Addons
-select "mounts and storage"
-select mount /system
-find and select TheameName.zip
-reboot
Thats what I did but the problem is that when I go to select the Liberty zip file it doesn't show up in the list of files.
Hope you didn't unzip file because you shouldn't have, the files needs to be copied just as it is downloaded onto you sd card... If you unzipped it into a folder that is you issue..
Continuing my "Therapy Through Theming" adventures!
After finally giving up on the Liberty battery tweak, I applied the Honeycomb theme. Best Liberty theme so far (A transparent notification drawer background is the only thing keeping it from perfection!), but I was left with the conundrum of finding a good, mostly blue, sexy lady wallpaper. Luckily Halo came to mind...
Then in the final hours, my scouring of wallbase yielded one of the grandest wallpapers I had seen in awhile, leading to this...
...and of course, good ol' WidgetLocker
Let's just say I'm not showing the folks at work this new theme....;)
Took my time tweaking my phone to honeycomb theme it and I must say I am very happy with the end result, that's saying a lot because I'm never satisfied lol.
Bootlogo is the red M with the honeybee, boot animation is the xoom boot, icons and notification sounds are from the xoom dump. About as xoom as it gets lol.
Likely this is a dummy question, but where are you all finding the widget/icons for Messages: 0, Missed Calls: 0, and so on - I would love to put something like that on my homescreen with Widgetlocker.
Thanks!
Hey I absolutely love that wallpaper Matt. I would really like to know the name and where to get it.
Thanks!
One im using is messagecenter....free in market. Wish they had a few more tweaks to the UI but I can live with it.
Reactions: ndwatkins
visionarysearchist
