Post Your Droid X Screens!!
Decided to embrace my newfound singledom with a sexy lady lockscreen. I'm so glad WidgetLocker FINALLY has proper theme support.
Screenshot capture for non-rooted phones in Gingerbread!
Hopefully that will help to get more people participating in this thread.
Actually I think this is actually kind of nice...
Well thank you sir. Actually I took the leap and rooted this weekend. Used z4 and Boostrap and everything as far as rooting went fine. When I went to flash Liberty using bootstrap I was unable to locate the LibertyX-1.5 in the directory. I was told that it needs to be placed in the sd root directory correct? I was in a tight spot because I did a clean data before looking for the Liberty file and when I did a reboot things were waaay goofy. After a factory reset everything was back to normal...and still rooted. I'd still like to flash that ROM but wondering what I might be doing wrong as far as placing it in the dir. One other thing and this may need to go into another thread but....once I install Liberty what is the best way to go back to stock if needed? Not sure if I completely trust bootstrap recovery.
Thanks.
Continuing with my sexy lady wallpaper therapy, here's the latest.
which became...
and just to do something different with the lockscreen
Thanks.
Make sure you backup with Bootstrapper before you do anything and then follow Liberty instructions exactly...
Install:
make sure you have root and clockworks recovery installed
-boot into recovery via clockworks bootstrap
-select "wipe data/factory reset"
-select "Yes -- delete all data"
-go back "powerbutton"
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select LibertyX/2-X.X.zip
-reboot
Installing themes or Addons
-select "mounts and storage"
-select mount /system
-find and select TheameName.zip
-reboot
dddd
