problem with emoticon
A
AC Question
hi!i have a problem with emoticon, it's look there is some i don't have like the peace one, is there a solution to get it? thank you very much
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
What phone do you have and what keyboard? Are they missing or do they show up but don't insert when you click them?
Sent from my T-Mobile Note 3 using AC Forums.
Almeuit
Moderator
Apr 17, 2012
32,277
23
If you didn't change it you may be using the stock Samsung keyboard. Are you in the US or elsewhere? Do you and your friend have the same carrier? I know in the US some things can be missing.
Almeuit
Moderator
Apr 17, 2012
32,277
23
You could try SwiftKey. It used to be a paid app but is now a free one... Lots of emoji support. See if it fits your fancy.
Or you can check the Samsung app store (should be called "Samsung Apps" or "Samsung Hub" ) and see if they have some more emoji icons you could download for the keyboard :).
Aitana135332
