now my phone wont turn on the screen with the phone and red triangle show up
Visit this link for more help.
http://forum.androidcentral.com/htc...568-how-unbrick-your-soft-bricked-evo-4g.html
Sent from my PC36100 using Tapatalk
He isnt even close to being soft bricked.
While your in the screen with the red-triangle, hit the volume up + power and reboot.
Root, Recovery partitions, and S-OFF are all mutually exclusive things... Just because you have Temp Root, doesn't mean the other two things will work. The full "Root" process will take care of all three (not just rooting the OS).
Just for clarity: I don't think "mutually exclusive" is what you meant.
Root, recovery partitions and S-OFF are independent - having one doesn't imply that you have the others. To flash ROMs you need to have all three.
Mutually exclusive means that if you have any one, you CAN'T have the other two. Which clearly isn't the case.
no but i was just trying to turn my phone on and that screen would come up and i would take the battery out for atleast 3 more times it would keep doing that until i just did the volume down and power did a clear data and cache and it worked
i was using the z4mod full root but it didnt work so ima go back to unrevoked
what is the S off
z4root won't do a full Evo root.
s-off turns the security toggle in the phones hboot to OFF, so you can flash files to the phone's partition that don't have an HTC signature.
oh ok thanks btw
how come when i unrooted my phone the s-off was still on how do i make it back to normal
Because you used unrevoked forever, the link at the top is a bit out-dated, check this out:
http://forum.androidcentral.com/htc...turn-stock-after-using-unrevoked-forever.html
i tried it through the computer and it keept on saying connection error but i went into reboot or bootloader and it now said s on but my phone is still rooted
