Questions as am considering an Unlocked from Samsung and using on Verizon
Hghlndr
418
70
28
So the title says it all and am asking since only have used carrier phones in the past.
Have a questions for those of you with these manufacturer unlocked devices on Verizon:
1. Does wifi calling work?
2. Does HD Voice and Video calling work?
3. Does Mobile Hotspot & Tethering work?
4. Any of you who've used Verizon devices and switched to unlocked versions on Verizon have suggestions?
I travel and use the above settings frequently on the road and have heard mixed reports in the past of non working scenarios, which made me stick with carrier-centric.
Any thoughts and comments would be appreciated as am
Seriously Considering this phone coming from the Note 10+, even though will miss the Spen...
Thanks in advance for your assistance!
Stay healthy and have a terrific All Hallows Eve! 🎃
I don't think my brother has any issues with those on his s20 ultra.
My question why do you want unlocked over Verizon variant. Just curious, as IMO I don't think you get that much benefit when you consider you won't get much if any support for unlocked phones from Verizon or any carrier if there are issues with it, you are stuck with crappy samsung customer service which will more then likely mean time without your phone they will have you take it in or send it in. Verizon will send out a replacement and don't have near the crappy customer service samsung has. And just because you send the phone in doesn't mean you will get your same phone back.
Hey man thanks for your advice hadn't thought about the warranty aspect. I'll have to speak with VZW about it as that could be a game changer.
Peace
Another consideration is if you ever decide to change carrier - no unlocking hassle.
Thanks for chiming in everyone!
I agree with your thoughts too. Since I live in No AZ will be sticking with VZW unless TMo impresses with its "country" coverage.
If anyone has experience with an Unlocked version used on VZ would love to hear you chime in on how the services work from my original post.
Thanks!
mirhafatima0128
