Rain - my phone it wasnt wet at all but now it wont turn on
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
Okay good.. its very simple.
You're going to flash two zip files through hboot and that's it.
The first one will downgrade the radio and return the phone back to stock (Verizon pre-installed apps included)
Its the MR1 RUU.. here is the zip: http://www.multiupload.com/KU7GSF2EY0
Make sure the whole file downloads.. check the file size when its done downloading.. it will be slightly under 399.35 mb
After you flash that zip.. delete the pg05img.zip from the phone.
Next place the second pg05img.zip on the phones sd card.. this will unroot the phone.
Here: http://www.multiupload.com/26WG1UZCXR
File should be about 243.82 (kb)
And that's it.. you need to rename those two zip files to just (pg05img).. you can follow the 8 steps from this guide http://forums.androidcentral.com/th...tore-install-roms-thunderbolt.html#post829088 if you're not sure how to flash radios.
Reactions: sleepyrey
karim174
