RAZR HD Maxx Questions and Answers Thread
Does this phone have a task manager like the GS3? I could close apps and clear RAM if needed. I usually did that every night when going to bed. With only 1GB of RAM I want to manage it properly. I don't want to download a 3rd party app if it is not built in. I'm thinking I have just missed it somewhere.
Did anyone see that Drive Smart Smart Action? I'll try it tomorrow but its now set to automatically activate when I connect to my cars Bluetooth system. It will send an automatic text telling people I'm driving when people call and text.
Sent from my DROID RAZR MAXX HD using Tapatalk 2
Disable the "Drive Smart" smart action. Or you can edit the smart action and disable the auto text message action (or delete it entirely).
Is there a way to get rid of Quick Settings when you swipe to the right of the home screen without having to install a launcher? It makes no sense for the homescreen to be all the way on the left, and quick settings isn't necessary, they should have just set up a second homescreen with all the toggles.
Sent from my DROID RAZR HD using Android Central Forums
I personally LOVE the quick settings.
Sent from my Droid RAZR HD MAXX
I totally agree and haven't found a way. I've switched to Nova launcher...and just added the Jelly Bean HD theme and love it. Still has the same feel with more options that seems like what should be standard.
One more question- my weather widget does not update as quickly as I think it should. Is there anything I can do for that? Thanks.
Sent from my DROID RAZR HD using Tapatalk 2
Anyone's Circle Widget not saving the 'circles settings' (accessed from flipping the battery portion of the widget)?
For instance, I uncheck all notifications from the widget..but eventually they later end up resetting to all checked.
Mine is the same as yours. A better question is does anybody's actually save the settings?
How do you access the circle widget? When I touch the battery one it takes me to something different I believe.
Yeah..it's kind of annoying. Don't need the widget to show me notifications. Have text and voicemail specific apps doing that already...
Agreed. The issue has been raised on the Motorola support site as well however the moderators apparently don't have the problem.
Yep. I fixed this by removing the Circles widget and putting a different clock/weather widget in its place. :)
Funny how we are all unique! I really like the circles widget. Even though I prefer Nova I am not using it because I can't use the circles widget. I especially like the notifications.
Please don't take my post wrong. I am not digging anyone else's opinion. I actually enjoy the differing opinions and flexibility of the OS.
issabelle77
