Read first post then post battery results
sure have
reboot is the only way to reset those times. There not counters for recharge like the iphone there counters for andriod up time.
Well, I've been wrong before.
I will check it out after I have finished my test today.
I just hit the yellow 30% mark.
08:41:16 Up time
07:25:41 Awake time
08:41:16 Up time
07:25:41 Awake time
Thats funny because 10 hrs ago you posted then your phone was on for 2hrs so your times dont add up and your lying
I'm just reporting what's on my phone.
If you want to call me a liar, you should use the contraction "you're", not the pronoun "your". :)
09:41:33 up time
08:25:59 Awake time
at 20%
Before you start name calling, you might want to check the facts.
Read the bottom part of that first post and you will see:
.... I accept your apology. ;)
Keep it civil. Disagreeing is fine, calling names, insulting, personal attacks will not be tollerated. If you need to brush up on the rules take a moment and hit the forum guidelines in my signature.
I thought I was being civil and responded in a polite way with the facts.
I even accepted his apology in advance. ;-)
Just got to 15%
Up Time: 26 h 0 m
Awake Time: 12 h 27 m 6 s
12:29 time unplugged
64% used on display
First day without charging during day.
As a Dinc owner, I have become paranoid on battery life.....so up until today, if my TB battery showed less than about 70% charge, I chickened out and plugged it in. Today I got brave and let it ride. AMAZING results!
Hopefully the pictures will show up showing my results. Basically unplugged for 12hrs 45min and still 60% battery left. I am 100% on 3g connection in Greensboro, NC. I am also using the stock battery. I push exchange email and gmail. All other syncing is turned off. I did do the Blockbuster thing to turn it off from auto updating. I Run Weatherbug in the background and it updates every hour. I would call today slightly lighter use of the phone, but since 5pm I would call it moderate use. I have never bump charged my battery, every night I plug it in before I go to bed and unplug it in the am before I leave for work.
I understand that since I don't turn my phone off that the up time and awake times are inflated. I showed that picture so that everyone could see the battery meter at 60%. I would call my day of phone use average and I could NEVER get this kind of battery performance out of my old Dinc with the 1750mah battery. Tomorrow am I will reboot phone in the morning and do another test and see how that turns out.
Very happy with battery and the phone itself.
PS...Will be in Charlotte, NC all weekend so I really get to test the phone and it's battery when I am 100% 4g. Will post results.
Up time 9:41 awake 3:45 battery 35%. Had the phone 1 day. Bumped charged only once.Hope this helps. How do these numbers seem?
Seem pretty darn good for day one. Are you using the OEM battery?
I got 13+ Up time on my OEM on day 5.
Yes this is stock battery. I did notice that it seemed to drop fairly quickly after 35%, but I was using it a good bit more than previously in the day. It got down to 14% before i stuck it back on the charger.
09:41:33 up time
08:25:59 Awake time
at 20%
No sorry proof is in the threads you posted http://forum.androidcentral.com/htc-thunderbolt/70990-1600-aftermarket-battery-test-3.html
Go look at his thread he posted at 7am with 2hrs on phone then posted later saying he had blah blah there is a 4hr diff. Now i see he edited the post at 9 so that might explain 2 of the 4hrs missing but who knows and i dont care i just wanted to know what people where getting on the battery no reason to lie. Htc said no more then 6hrs so if your reporting more then 6hrs on oem its a no brainer. Now he does have 200 extra ma but that is about 30 more min of use time if you do the math compared with what others are saying they get for awake time.
Just got to 15%
Up Time: 26 h 0 m
64% used on display
You have to restart the phone after full charge as the numbers are not correct.
Charge phone - unplug- restart- get battery low then post numbers, Thanks
What you are getting is what i get. Do you have your screen all the way off and 4g off and all push, updates off like i do as well?
Thanks
uptime 10:00 awake 2:25 20% left.
ouch thats a little on the low end. I was only getting 2hrs when i had 4g on and the screen at 50% with push set for every 4hrs. I bet if you turn those off you can do a little better if you need more time? I need 16hr day with no charge and med use.
Thanks
These numbers are all wrong. You must once again charge your phone, unplug it, restart the phone, drain it down then post your times.
from the looks of it you had it on for 3 days and got 12hrs and are on the 4th charge so i would guess if you fallow the steps above you will get about 3-4hrs of use on a charge.
How is this good? What this is saying is she/he got just under 4hrs of use on the phone. Uptime dont mean anything besides when it was turned on but it was sleeping outside of the 4hrs. Htc said you would get 6hrs.
I bet if they charge there phone and play with it non-stop it would die in less then 4hrs
xinyingt2
