[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
wow thanks guys you are the best. i finally have SC 2.9. thank you so much for the help. and i learned how to manually flash update. thank you again!
Ok, I'm completely lost. How did you get from installing voodoo to now flashing some unknown thing in ODIN to now flashing sc 2.9 so quickly? Please share all of your steps here so anyone else who does the same thing can learn from your experience. That is part of the whole point of these forums, sharing information so everyone can learn.
ha ha sorry land shark for the confusion
1. download this package from droidxcon "EB16SC28_DXC.tar" it was non voodo and sc2.8
2. i used pda button and put my phone in download mode and ran odin to restore my phone back to non-voodo superlcean 2.8
3. rebooted my phone to verify that it can reboot. and saw the cool honeycomb boot animation :)
4. copied the ROM: Non voodoo super_frankenclean_2_9nv.zip from Adrynalyne to the root of my SD card
5. powered off my phone and booted into recovery "hold down both volume button and power till samsung logo reappears and was taken to a blue recovery screen
6. selected apply update.zip to take me into red clockwork mod and selected "install .zip from sd card" located the update for SC 2.9 and installed it.
7. rebooted my phone via clockwork mod and successfully nstalled 2.9 on my fascinate.
Sorry guys i forgot the whole point of fourms. thanks for correcting me landshark
Thanks for sharing. I learned something there too about going from voodoo to nonvoodoo. You definitely have it down pat on how to flash things to your phone both through ODIN and cwm. And not correcting, just reminding.
I just want to make sure I understand this, as I am new to this, I used DroidXCons packages to install 2.6 and 2.8, but I can just download the nonvoodoo 2.9 zip and flash through red cwm. no odin needed?
i have a question for you "landshark" about flashing roms download from rom manager. where should i ask this or just PM u
yup, just make sure you download the nonvoodoo version. ;)
personally I'd avoid rom manager and just install via cwm. What are you wanting to flash?
well i wanted to try a "build your own blackhole rom" i have it all download on my sd card but its just a buch of .zip files
the rom is based of the eb01
Not to be a crybaby, but why is the EB16 (or wherever it came from) Email.apk being included with this ROM (which has a broken signature setting) instead of the Email.apk from EB01 that works great? I was able to edit the zip package to head off the clock and launcher stuff (i prefer the real deal as opposed to the thin AOSP fluff) but forgot about the email.apk and as such my settings were torched after going from 2.8 to 2.9. Not a big deal, it would just be nice if that bug were finally kicked out for good.
That might deserve its own thread since it doesn't really fall under this or DroidXcon's thread. I never really had any luck with RM even on the OG Droid so I tend to stay away from it.
ok ill try to start one in a few. thanks for the help i really appericate it.
Will Chris' battery mod work on sc2.9? This one doesn't show the battery percentage when plugged in.
My thoughts exactly. I was going to say PM me so we don't clutter up Adrynalynes' thread. Thanks for all the help PJnc284. Decaydance99, when you start the thread maybe title it something to the effect of asking the differences between rom manager and cwm. I don't think there is a thread out there like that, and we just have to make sure we all stay on point of what the differences are and not turn it into a bash rom manager thread.
Does cwm 3.0 work with 2.9?
No, it requires the "edify" package type whereas the 2.9 zip is "amend" type. Whatever that means. I tried it and it didnt do jack. Just flash the "CWM-recovery-ALL.tar" via odin and you are all set.
Don't believe so since the Edify script required for cwm 3.0 was causing issues and Adrynalyne changed back.
From the OP:
I release superclean in two versions currently, voodoo and non voodoo. It includes recovery kernels for both. These roms support clockwork recovery 3.0 ONCE INSTALLED. They cannot be installed with CWR 3.0, due to serious issues I had with Edify scripting. This goes with the patches as well. Some, if not all of this probably stems from the fact that we are using BML partitions, while the rest of the sane world uses MTD. It may also be that I need an update binary from Samsung and not Google. I'll have to investigate that.
From the OP:
RIF - Reading is fundamental. Make sure to fully and carefully read Adrynalyne's first post before asking questions. He spent a lot of time updating his thread and adding the questions and answers to his first post. If you do not find the answer to your questions in the first post, then fire away and someone will be around to answer your questions as soon as possible.
Because nobody deemed it fitting to report it to me.
When I am dealing with PMs, emails, two high traffic forums, AND IRC, there is no way I can read everything posted.
This version won't make my coffee in the morning for me.
Consider this as reported so it can be resolved.
K,
Thx,
you da best
w1inona
