[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
hi im running sc 2.9.1 and keep getting gmail fc someone please help
Tried full wipe and re-rom your phone? Reapplied kernel? No theme?
did you do a data and cache wipe?
Sounds like the common problem that happens when coming from Eclair to Froyo using the no wipe package (the one with the x after 29) instead of the wipe version. I guess DroidXcon is going to have to make his Warning in bold red lettering about going from Eclair to Froyo without wiping causing force closes and other problems
ABOUT THIS BIG
ABOUT THIS BIG
lol.
So far DL09 modem seems to be working pretty well. I'm getting phone calls now, which is a good thing.
I did find one other bug with 2.9.1, but I've had it ever since 2.6. Whenever I open google maps and don't have gps turned on, it will ask me to go to my settings. When I click that button to go to location settings, my phone just hangs and comes up with a force close error.
huh. mine doesnt do that.
How did you get that sorted? I had the same issue.
Well first i used root explorer to name the android music player to music.bak(incase something got borked). Then I flashed the twmusic zip provided in the op, followed by the drm in the op as well. its good to go now.
can someone help me with cwr red.. after i enter recovery mode, i get into blue and press apply sdcard:update.zip, then it goes into orange and i press install zip from sd card. then i go to a file where i have an update zip, then it takes me to red recovery. there any way to get straight into red instead of going through this process?
1. Since you are on superclean 2.9, flash this cwm-all file MEGAUPLOAD - The leading online storage and file delivery service through ODIN and you will boot directly to red cwm-all first, then in red you don't use apply sdcard.update.zip.
2. DO NOT DO ANYTHING IN ROM MANAGER, DON'T TOUCH IT AT ALL. That is how you ended up with orange cwm.
Follow this guide set up by DroidXcon, and it should clear things up when it comes to cwm: http://forum.androidcentral.com/ver...-clockworkmod-recovery-w-screen-captures.html
Reactions: pitokellie
the videos on cnet.com play at normal speed but the audio is way slow. (except the ads, which play fine?)
The flash videos on other pages play fine, cnet.com is the only site I have problems with. Is this a webpage problem, or phone problem?
I have tried three different browsers to no avail. I have tried using flash 10.1, and now 10.2 to no avail.
Could you all check to see if cnet.com videos play fine for you all?
I have 2.9.1 with the EB16 kernel. Debinged browser.
Thanks
Thanks
same here
sarahsda
