[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I have spent the last 2 hours reading over this thread.
I. AM. OVERWHELMED. :)
Maybe I'm tired!!
LOL, don't feel bad. I tried to read through one of the encyclopedia stickys when I started, and it soft bricked my brain. I rebooted like 3 hours later with a wet spot on my shirt from drooling.
I would just read the main posts very carefully 3 or 4 times. Most of the stuff you're reading about in here is from people who didn't.
GO GO JAMPOT! YOU CAN DO IT! YOU ARE HOT! *high kick* (That's gonna stick in my head for a while LOL)
Reactions: SSmaster
It's always worked for me, except sometimes when it doesn't lol
Another good player for shoucast stations is A Online Radio for some reasons it has stations winamp doesn't have so I use both.
On a side note, I'm in love with Power Amp. I like that it plays files by folder, which none else seem to do. Really handy for techno mix cd's where the artists are all different.
Or I guess mix cd's in general, but what is this, the 80's?
My battery tanked at first yesterday too. Give it a day or two to really compare results.
sharky, this is hilariuous, I unplugged my phone did some lite usage and the battery dropped 4% in about 7 mins! this is with infinitys unvoodoo kernal. ill give it few more hrs, hopefully something good comes out today or tomorrow. What is the battery wipe stats easy fix just clear stats while at 100%?? Thanks sharky and everyone else
Haha, yes, my brain feels soft bricked!
I'm going to go over the main posts carefully today and figure this out. I really want to understand what's going on.
Thanks for the support :D
*High kick* hehe. Yay, me!!! woot woot
2.9.2 is up and running smoothly. I've installed the boot animation and theme that I like. Only thing left to do is get touchwiz running. The launcher I got from the original thread does a force close loop (I found that out the hard way). I found one on XDA that works, but it uses 5 dock icons, and the main reason I wanted to run touchwiz in the first place was to have 4 dock icons. Does anyone have any suggestion or advice about how to get touchwiz running?
is the touchwiz.zip that's on the 2.9.2 thread different than the one that's on Andry's original superclean thread? I tried to install the one from the original thread and it doesn't seem to jive with 2.9.2.
Are you talking about the one I posted for you not working well?
I'm pretty sure they're the same, what do you mean by it's not jiving. Can you explain the problem a little more.
it's just force closing. i can't access the menu or root explorer to get out of it. had to re-flash 2.9.2.
Edit: And I did wipe my cache/dalvik.
And you're using the launcher that came with 2.9.2 correct.
Give me a sec to find the thread with the folder to delete and I'll get back to you, or someone can chime in with the LP fix in the meantime
*EDIT*
Launcher Pro and EB01 S.C. 2.9.
"It's not Launcher Pro and sc 2.9 that don't get along and won't let you save your changes, it's LP and the AOSP launcher that comes with SC. I had the same problem and it was really aggravating me that I couldn't keep the 3D app drawer. Here's what you do. If you don't have Root Explorer, get it from the market. Then open up root explorer. You will see a bunch of file folders listed in alphabetical order. Scroll to data and click on it, then scroll to the data folder on that page and click on it, then scroll to com.fede.launcher, long press on that folder and choose delete from that menu. Then scroll to the top and click on the folder that says parent folder. This will take you back one page, now click on parent folder again. On that page click on the dbdata folder, then click on the databases folder, scroll to com.fede.launcher here too and delete it. Now scroll to the top and click parent folder at the top of each page until you don't see the parent folder at the top of the page and hit the home soft key. Your changes in LP should save now. If they don't after that, a reboot of the phone should completely fix it."
Sharkie
oh, i should also mention that i'm not flashing the touchwiz.zip file. I just took the TouchWiz30Launcher.apk out of the zip and placed it the system/app file. This worked for me fine on 2.9.1, so I don't see any reason it should be causing problems now. I'll flash the zip and see if that works.
*EDIT*
I apologize for my ignorance, but I'm even more confused now. I wasn't aware that LP was in the equation at all. In any case, I flashed the Touchwiz.zip and everything seems to be working now. But don't worry, you can be sure I'll come crawling back if something goes awry.
Did you just place the .apk in the system folder or did you install it as well? Just curious
I meant last time, did you just move the file or did you move it then install it? Because that might have been the problem.
Hopefully this question has not been answered a billion times, I searched heartily but perhaps I missed it:
My first custom rom was SC 2.9. I noticed all was working well, and I had a choice of all these lock screens. I use the pattern unlock, but I played around with the different lockscreens and left it on AOSP. I flashed the 2.9.1 patch, then the 2.9.2 full ROM in CWM. When I got a call yesterday, I realized that there is no Ignore function on the AOSP lockscreen, so I went to change it back to Puzzle Unlock, since that has Answer, Hang up, AND ignore options when a call comes in. However, I go into my display settings, and regardless of which one I pick the AOSP stays active. Any ideas how to get my puzzle lock back?
I did a double wipe of data and all caches. I reflashed CWM 2.9.2. The first thing I did was make sure Puzzle Lockscreen was turned on. Without pattern lock turned on, the puzzle lock came up. Yay! however, when I enabled the pattern lock screen for security, when the phone rings the AOSP lock screen comes up, even though I have never selected it with this fresh install. Is anyone else experiencing this or can you replicate the problem?
stopwatch
