[Retired][ROM]Superclean 2.9.2 EA15/EB01/EB16/EC10 Based
I use winamp and the controls show up on the lockscreen. Not sure with the stock player.
This message was sent via Tapatalk
Reactions: Landshark
how do i apply superclean rom to fascinate?
Please get me an instruction about how to apply newest superclean rom to my fascniate. i just root my phone to newest version. Thank you.
I have tried poweramp and now winamp and i still cant get the controls to show up on my lockscreen (ive tried them all by the way).
Im thinking about reflashing as this kind of bothers me.
You know this phone or android in general has lots of quirks. I see some folks have problems I never have. It's really hard to diagnose problems with the many differents setups and apps ppl run. Even a theme could cause problems with all the framework changes, really hard to track down culprits of some probs. Good luck.
I use PowerAmp and the music controls do show up on the lock screen when music plays. Did you change the settings?
I don't know that it is so much this phone or android in general as it is the broken POS EB01 build leaked from verizon/samsung. Adrynalyne has done a great job of cleaning it up, but he can only do so much without the source code.
Na, i didnt change any settings..just the stock player and even stock SC 2.9.2 and infinitys voodoo kernel with no theme and very few apps. and no music controls on any lock screen.
Are you using any lock screen apps (widget locker and such) that could block you?
I believed he removed them because of the crashes and random reboots reported.
Flash this ROM if you can when the device is full on battery, clear dalvik-cache and cache partition prior. But I recommend a TB backup beforehand just in case.
Yes SC 2.92 contains EC10 kernel and ROM.
BTW all this information i provided I pulled it off the OP, just read it throughly next time =P
Thanks!
Worked great, yeah I read through the guides but I just wanted to make sure because I didn't want to screw up my phone and have to do it over.
No..infact the only apps/widgets i have installed are
Fancy Widget (for weather and clock)
Yahoo Mail
Root Explorer
Pandora
Dolphin HD
Facebook
Winamp
Had poweramp but just uninstalled to try Winamp
Voodoo Control App
Inkpad
Samba Filesharing
Quadrant
Thats it...the rest of the apps are stock Superclean 2.9.2 apps..i know pretty boring huh
First thing to try which will be the least intrusive and require the least amount of work, go to our dialer and dial *228, wait for it to connect, choose option 1 to program your phone. Phone will reboot automatically. Dial *228 again, choose option 2 to update your roaming capabilities. Phone will reboot again.
If that doesn't do the trick, flash this in ODIN:
eb01modem.tar
mine has done the same thing since i flashed sc29, just tried the *228, will see if that fixes/helps
I'm at 2.9.2sc non voodoo with the EC10 kernel w/ lagfix file on the sd card. If I want to flash DL09 to try a different radio do I need to get rid of the lagfix file before or after or does it even matter in this issue. I thought there was a reason to dump it if you were making certain changes.Also do I need to clear any of the caches? Thank you in advance.
If you are just going to flash the DL09 modem/radio, no wiping caches. Just flash the DL09 modem through ODIN.
Reactions: mm247
Running SC 2.9.2 Non-voodoo on fascinate. Sorry if this has already been asked, but right now whenever I send out regular SMS texts they are sent out blank. Is there a simple fix to this, or will i have to flash a new rom? I apologize in advance for the rudimentary questions.
Don't be sorry, never be afraid to ask questions. It's how we all learn new stuff.
I would venture to guess you need to reflash your modem. Are you talking about regular less than 160char texts?
Yup, just regular ones. I tried having someone send me a text and I didn't receive it either. How would one go about reflashing a modem?
5GController
