Ringtone and Notifications volume auto decrease
A
AC Question
I've had this phone for a few days now. I'm having an issue with my volume settings...they seem to adjust themselves. I have them set where I want them, and without touching the phone they adjust themselves (the Ringtone and Notifications only) to a mid range level. I do have Power Saving mode disabled, so I'm sure that it is not the cause behind this issue...
Is there any way to fix this problem? Thanks in advance.
the tall guy
Q&A Team
Sep 23, 2013
7,210
Hi, thanks for joining Android Central :) do you have anything in your settings that would indicate the decreasing / increasing? do you have anything ticked like "increase volume while in pocket" or something like that? it might not be in the volume settings, it might be in the accessibility settings.
Failing that try downloading volume locker from the play store, see if that helps.
Longhorn
