Robin's LG V10 Thread
How?
For Off, you can either double tap the status bar, or install a Screen Off app from the Play store and set that app as the double tap gesture in Nova (gestures require the Prime paid version of Nova).
Screen on works as it normally would.
Re: question about lg keyboard
This is a known issue with LG phones. I think the G4 does this too
Posted via the Android Central App with my two thumbs.
Indeed it does. It's just a notification however. You don't have to actually select a keyboard. I believe it's actually a feature rather than an issue, allowing a quick method to change the keyboard when your in the middle of an application. For example, I typed half of this reply on the LG keyboard, then used the notification to change to the Google keyboard and type the rest. I can't think of a reason why someone would want to do this though.
Agree with JayWill. On every Android device I've used, a keyboard notification icon appears in the status bar when typing, to allow you to switch keyboards on the fly very easily. If you only have one keyboard installed, then you probably won't see that icon (and if you do, then it's probably a minor bug).
For me, this is my first LG and came from the HTC line of phones. On all of them you can press and hold in any text input area and then pop ups a menu to select the keyboard. But LG's method does not bother me, it just took me b y surprise the first time it happened.
Re: trying out the stock launcher
Wow thanks.
Correct. I used the app called "screen off".
when looking at webpages..I've noticed....
Sometimes the brightness will go in and out...how do I change that
Re: when looking at webpages..I've noticed....
Turn off Auto in your pull down menu.
That should do it.
another screen glitch
The screen got extremely contrasty when I got out of the calender. Should I do a fdr?
Re: fav email app
I'll try that one again...the inbox by gmail is too confusing for sure
I've grown to really like Inbox. It just takes some getting used to. I use Mailwise for my work exchange account which I also really like.
Re: fav email app
I'm still using gmail for my personal email but for my work's Exchange/Office 365 environment, I use Nine. It is amazing!
FDR really helps
I know various apps can cause issues. Now that I did a FDR...no glitches.
forgot how to add selections on bottom screen
Hi folks how to I get to the menu to add options?
tetee3000
