Robin's LG V10 Thread
global network vs cdma
Hi folks I had a strange thing happen. In the settings the network chosen was global and I couldn't call out. When I selected cdma it worked.
Re: location notification
How do you clear that out?
If you're talking about that annoying notification. Go to settings - location - more and select battery saving. The notification should stop.
Thanks it finally went away...I was toggling various settings in the location menu...but don't even know what fixed it.
Sorry.. I meant to say mode.
LG V10 - Brightness Issue
Every once in a while during typing or accessing various apps the screen will fade in and out...I'm wondering if this is defective or the two cameras try to adjust.
Re: help this is maddening
I think you may have done it already, but did you disable the auto brightness?
Been chatting with tech support and they had me turn off the weather animation and that seemed to help.
Re: LG V10 - Brightness Issue
Can you be more specific? What setting is this exactly? Just curious in case I notice a similar issue.
lg world themes
Hi folks can you post the link to get the various apks for the keyboard skins? I know Verizon disabled smart world so there is a way around it.
just changed animation scale to .5..
Changing the animation scale to .5 speeds up the phone. Under developer options.
Re: just changed animation scale to .5..
So you didn't return the phone after all?
fiscoking
