[ROM] [04.19.11] BAMF Remix 1.5 - New base RUU plus more! *UPDATE*
I'm hoping someone here might be able to help. Ever since I flashed 1.5 Remix I've had one problem that I can't seem to fix. The app is Alarm Klock and any time the alarm goes off, after a few seconds, I get the following error message (see picture). The app worked perfectly before flashing rom and the error is always exactly the same. I've removed and installed the app three times and fixed permissions through rom manager. My process was as follows:
Data wipe the TB
Root.
Left it at root only for a couple of days (app worked fine at this point).
Then data wipe and flash of 1.5 Remix
Cache and dalvik wiped each time.
Installed Alarm Klock from the market (did not restore with TiBu)
The error started right after 1.5 Remix was flashed.
Any suggestions will be appreciated.
Thanks.
Data wipe the TB
Root.
Thanks.
You should email the alarm klock dev and let him know your situation.
Tfunz
