[ROM] [04.19.11] BAMF Remix 1.5 - New base RUU plus more! *UPDATE*
Hello, I am a frist time Rooter and after I rooted I flashed the rom with BAMF 1.5 remix.
Everything seems to going well but I am noticint some lags when opening certain apps and some random program crushes. Is this a normal stage until the phone is "used" to it?
Also battery drained 25% just normal use.
I follow the exacty direction...
Download ROM.
Reboot into Recovery.
Perform Nandroid backup
performed full wipe (data/dalvik/cache).
Flash ROM.
Reboot.
I also have the lastest radio pg05IMG
ps. It also freezed a couple time in the middle of closig out or opening a program. screen just went black but the button 4 key are light up. wait for a few minutes and it was just stuck in that stage, so I powered off but the phone won't power back on until I pull the battery. Any idea?
Remix is really working great for me so far on the new radio. Only weirdness outside of my next note is when I boot up fresh with a new battery the phone struggles to hook onto 3G (no LTE here).
My question though is I can't get the speech to text to work (aka trying to voice dictate a text in the car). The mic icon comes up but it never registers as hearing me.
I frequently use a bluetooth headset but with it on or off it doesn't work. Any ideas?
Thanks in advance!
It works fine for me. Did you wipe data/caches before flashing?
Thank you for the rom, Just flashed it and works noticeably better.
Quick question, If I flashed using the "1.5 Remix By ThatDudeButch" ROM, do I need to use the radio ROM thats listed under the 1.5 Base? (" 1.5 Base By Adrynalyne - Radio: Updated 4/19/11 @ 9:36PM")
you don't have to if you don't want.
Reactions: QuickSack
Thank you for the response.
I went ahead and flashed the new updated radio(1.16.00.0402w_1) in hboot, everything went fine. Is it ok if I installed BAMF before installing the new radio?
also do I need to reset the battery or anything like that after updating the radio?
(Doing all this to max battery life, did setcpu to smartass also)
where is this radio?
you can flash the radio/rom in either order it doesn't matter.
after installing the radio you could clear data in setcpu if you use it, then reboot the phone and autodetect frequencies in set cpu over again.
if you use battery calibration app, after each flash it is recommended that you charge to 100 then unplug and wipe battery statistics (calibrate).
What radio do I need for this ROM? I am still on rooted stock.
you dont need the radio but it's the leaked ruu that will be coming ota shortly to unrooted devices.
You know how in stock, you got previous apps in the notification area
Now we got the controls. No way to change that, or its just like that. And if so, any other roms that do have it
Not sure exactly what u mean but u can get your recent apps by long pressing the home key
Ok, I mean recent apps you've opened in the notification area once you pull it down
Just like holding the home button down, but instead you pull it down. Its like that in stock
Yeah i get that, what i didnt understand was the second part - do u want the recent apps back in the bar?
i flashed this, and the notification bar has a space where the power widgets are supposed to be but nothing is there. I tried reflashing the power widgets and its the same thing
Das BAMF 1.6 Remix up and running using Imoseyon's LeanKernel Normal 1.2.3 and it feels SWEEEET!
how the hell are you supposed to read the email if you can see them until you click a random one
tsmtoolpro
