[ROM] [05.25.11] Das BAMF 1.7
Thanks guys.
Additionally, I sometimes have a very high drain on idle. This has occurred before I rooted, but was wondering if anyone knows the cause. It's after I take it off the charger, about an hour later after not touching it the phone is physically hot, the current is over 300ma and I am down to 85% on the extended battery.
maybe a rogue app - check battery usage and see what's using up large amounts of juice.
could be your radio - what radio are you on and have you tried any of the other options?
Try wiping the data, cache and Dalvik 4-5 times BEFORE installing the ROM. Kinda works for me. I am averaging at 50mA now..
Can anyone comment if wireless tethering works with the Wireless Tether Root app? (This is NOT the Mobile Hotspot). This app was pulled from Android Marketplace, but it's still available here Downloads - android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting
The app works just fine in BAMF 1.6.3, but not in BAMF 1.7 (normal or REMIX). The app install just fine, it started fine, my laptop and iPad connects to my Thunderbolt, but NO DATA CAN BE TRANSMITTED.
Wireless Tether works great for me on 1.7. It actually works much better than the Mobile Hotsspot.
Just flashed 1.7 remix after coming from 1.6.3 nte and did a complete wipe beforehand. I reinstalled all my apps using Titaniun Backup (apps with data but not system data) and some apps work but many are force closing without opening at all. What should I do? (thanks in advance for helping out a newb)
Sent from my ADR6400L using Tapatalk
Fix permissions in rom manager then reboot
Or reflash but wipe multiple times
Reactions: QUIK_LS1
Alrighty fellas, DLing now, and reading this thread to build my base knowledge so I don't ask questions already asked, and safeguard my first ROM flash.
Can you guys confirm my plans? -- If I Titanium backup, my apps should be all good, and I plan to use mybackup for SMS & call logs, and my contacts are in Outlook via HTCSync. Am I missing anything else that I will want to restore after flashing?
Really anxious to give you guys a swing as my first custom ROM!
You can also use My Backup to save your home screen icon setup. After you flash, restore your apps using TiB first then restore your icons using MB. It takes a while to restore but just let MB run, then reboot when prompted.
Sent using Tapatalk
Reactions: project.in.process
See my guide here on whole apps and settings backup procedure, should answer some of your questions...
http://forum.androidcentral.com/thu...store-apps-data-when-installing-new-roms.html
i flashed then remix1.7 last night and its working great! The only thing is that my battery life has cut down by almost half. Before i flashed i was getting good battery life but now it sucks... any suggestions on how to fix this . Im running juice defender and have my settings adjusted. Also, i cant seem to find the back up assistant app and cant get my contacts. any help would be great!
Thanks guys! I use simi folder so I'm set with my homescreens, as the rest is pretty much widgets, except for a few icons on the main homescreen that I can handle. I'll def review your guide!
I went from 1.6.3 NTE to the 1.7 Remix early last week. Had the same battery issues the first 2 or 3 days, but it eventually settled in. You can try this:
Charge your battery to 100%. Go to BAMF toolkit, and under troubleshoot, clear the battery cache (which includes a reboot). After it boots back up, let the battery drain down as much as possible before recharging it back to 100% again. Doing this after installing new ROM usually helps get my battery settled back down.
Not sure about backup assistant, I always just let my contacts sync with Google (plus back them up with My Backup, just in case).
Reactions: Bakafish
Does anyone know what the "Patch for 1.7 Rosie" patch does?
[ROM] [05.28.11] BAMF Remix 1.7 - LINKS FIXED! - xda-developers
It's just under the download 1.7 remix link.
Changelog for 1.7
  • Nuked pulldown header totally and remapped and resized clear button to under notificatons
  • Sped up Rosie animations
  • Added some source built AOSP gingerbread libs for MOAR speedz!!!!1111 (lol)
  • Changed battery images to green at high end (ZHP Pilot)
  • Optimized all images in framework
  • Nuked some more useless drawables
  • Added new lockscreen to Post #2 on XDA
BAMF Remix 1.7: DOWNLOAD
MD5 SUM: 2fdf7a332230fb0cca0f3d7133e36673
Patch For 1.7 Rosie (Please install this via clockwork after flashing the ROM above):
So just download both at the same time, install 1.7 and then reboot...then install the patch?
Crusher
