[ROM] [05.25.11] Das BAMF 1.7
oh ok, I feel like an idiot. I was looking for the word root. Thanks for all the help.
truth be told, first time i did something that required placing a folder/file @ the root of my sd card i actually made a folder called 'root'.
but, i did place that folder on the root of the card. so. it was somewhat of a triumph.
Just glad I'm not the only one who had issues when starting out. This place has been great for trying to learn and for finding helpful people.
So why does SMS bog down and become real real laggy (often requiring a reboot) before it works like normal with all the 1. Something bamf? The problem went away with the 2.0 versions.
There is an option in the Bamf Toolbox to remove some unwanted apps, including Friend Stream. It was my understanding that Friend Stream was required for Sense to operate, and should not be removed. Is it safe to remove this app?
Sent from my ADR6400L using Tapatalk
Its not just BAMF roms, it seems to be a froyo-wide issue (I haven't tried a GB one yet).
Key is, keep you total # number of messages from getting too large, or so ive heard. I switched to GoSMS, and haven't experienced a slow down since...may want to check that out as well.
I'm having a problem, my screen keeps turning on when I adjust the volume when listening to music. How can I shut this off?
This ROM wakes the phone whenever you press one of the volume buttons. To disable this feature, download the appropriate mod from the OP of this thread and flash in Clockworkmod.
Reactions: d1ez3 and zero neck
Theres a disable wake on volume key press mod, its a zip file that you flash in cwr, can be found in the op.
Reactions: d1ez3
having a brain fart--
OP just posted a mod to disable AMPM & VerizonWireless from lock screen
downloaded, placed @ root of card
do i rename it PMG015IMG
or can i leave it the name of the zip by the OP?
i e ven just did something like this yesterday--just having a complete lack of mental capability at the moment.
about to dl/flash the "disable-volume key turning on screen". realized how much i don't like the screen turning on when trying to turn up music.
additional edit:
original problem: couldn't get texts to send/receive after flashing this theme.
posted problem--
resolved:
earlier today, after installing the theme--i blocked a spam text # on vzw website. apparently, that also shut off my text messaging. no clue why.
i went there just now, unblocked it--sent myself a message & it delivered.
has nothing to do with the Theme, apparently.
sorry to take up so much space
i've since deleted my subsequent posts/ edited this one to keep this thread shorter :)
thanks guys!
Possible that something didn't work right when you restored. Do a full data wipe on addition to wiping cache and Dalvik. You may want to do this three times before restoring your backup again. Good luck.
Reactions: project.in.process
Thanks guys.
Additionally, I sometimes have a very high drain on idle. This has occurred before I rooted, but was wondering if anyone knows the cause. It's after I take it off the charger, about an hour later after not touching it the phone is physically hot, the current is over 300ma and I am down to 85% on the extended battery.
gurusdex
