[ROM] [05.25.11] Das BAMF 1.7
If you don't flash the patch, the phone icon is there, then next to it is the word "phone" which looks very out of place, the patch removes "phone" spelled out
Gotchya...and I found the patch on page 400 of the xda thread (gotta love the search function).
quick question. i downloaded 1.7 flashed and all is well. when i go into rom manager it says i have 1.6.3 as my current rom. any ideas? thanks
I apologize this is off topic but I was wondering on the xda developer threads, how or when do I get to post or reply to a comment? It says i don't have permission.
You need to have a certain number of posts before you can post in the xda ROM development threads. You can post in the non-development threads to build your post count. Don't recall what the required minimum is though.
This somewhat a known issue...mine still says 1.6.3 on the software info page as well, but I definitely Have 1.7 installed. Wiped before install and everything like that too... Not too worried about it.
I believe 10 posts is the magic number.
Reactions: skamania
Is there anywhere i can get some cool themes? im running remix 1.7. i saw some themes with the clock not as digital but written out? does anyone know how they did that? THanks!
Could be beautiful Widgets.
Sent from DASThunderbolt
clock spelled out
One of the best apps for spelling the time / date and other stuff out is minimalistic text. Free.
Also if you create a fonts folder on the Sd and tell the app where it is, you can use any font for the text. Awesome app.....
having the unexpected browser closing problem and read that im probably missing flash. what is required to resolve this. thanks.
Is there a settings somewhere in BAMF to have the screen not turn off when it is plugged in? I found the settings for display to turn off "never", but if the phone isn't docked, I want it off. Ideas?
I mainly want this because I just got the Seidio desk charger and I want it to have my "gentle alarm" app running while at my desk, but it keeps turning off.
How I'm getting around this no is to put it into Car Model manually and then go to my gentle alarm app. Just trying to streamline the process by not having to go into Car Mode if it's not necessary.
Thanks.
Thanks.
I haven't tried it, but go to "Settings --> Applications --> Development" There is an option there to stay awake while charging.
I just downloaded the 1.7 and I'm new at this do i need down this radio too?
Please note, this release has a new radio to complement it.
Multiupload.com - upload your files to multiple file hosting sites!
Put it on sdcard, reboot to hboot and flash.
Note: This radio is re-released to include the LTE modem as well (mah bad). Check your MD5s! If it doesn't match, downlaod this until it does, and flash.
I assume you have the original radio, so you don't need to flash the updated (OTA) radio to go with bamf 1.7, as long as the radio you are using now works well on your device you're good.
Does anyone have an issue with the bottom of your screen "flickering" especially when entering text, such as when you see the cursor blinking? I am wondering if mine started after I flashed my custom ROM or if its hardware related. Thanks in advance.
Sent from my ADR6400L using Tapatalk
ok, so I've been running 1.7 for the past two weeks or so, but I've had to data wipe and reflash 1.7 last saturday after my messaging was force closing and I couldn't get it back up by wiping cache nor fix permissions nor re-flashing das bamf on top of it. today, I rebooted since I was getting data errors and once it booted back up, messaging and phone are force closing, with the phone in a force close loop and the data doesn't seem to be working. I tried fixing permissions, wiping the cache, re-flashing 1.7, and re-flashing the radio, but no dice. any ideas what could be causing this or what I could do to fix it besides data wipe and reflash?
TheGreatApe00
