Re: [ROM] [10.02.2011] Boodoh V2D [LG-P509] [Froyo 2.2.2]
OK, So i installed the ROM again. And SIP didn't work with exact same settings as i did in factory ROM.
I was using SIPDroid and basically as soon as I configure my user/password/proxy/host it shows a green dot if i am using factory ROM. But here it keeps switching between yellow and red dot.
So i installed another app, CSipSimple. This one worked but somehow this app is very painful to use. Then i tried another app VoXMobile. This one worked too. So i guess it's SIPDroid which is not working. Not sure why one app wouldn't work but other would. But anyway i have a solution till i hit another problem.
Thanks for trying to debug the issue with me.
Interesting, if you still have problems after a complete wipe and reinstall please provide the following:
SIP app your using
PBEX configuration - minus any acct or personal info.
As detailed of a description as you can provide with regards to "not working"
Just thought of something, this rom includes an adblocker. The SIP and/or stun server you're connecting to may accidentally have been included in your HOSTS. Disable the adblocker, reboot and try again.
