[ROM] 10/12 - CleanROM *Dev Edition* 1.2 - Performance and Style!
Re: [ROM] 9/29 - CleanROM *Developer Edition* - Perfomance and St
I dont understand your question?
I am not sure but I think he(she) might be refering to the fact that the cores in the evo 3d cpu are asymmetric and that the second core doesn't come in to use until the first core is maxed out, either that or something to that effect. So I guess his(her) question would be if the second core comes into use at 1.2 or 1.6 since its now been overclocked? Or I could be wrong as hell and just wasted time on this post, LOL.
Here is what i get....it happens only in the bookmarks page and will happen to any bookmark i choose....and like I said it doesnt happen all the time its every now and then......
I'm noticing a hint of lag here and there. I suspect it's because I didn't do a full wipe before flashing from 2.5.
Ahhh, i see. Well then with that being said...
I have no clue! lol
Thats really lame! Dont know why it would do that. I will check around and see if anyone else has the issue.
Hmmm. Dont know why either. Full wipe before 2.5 is not TRULY needed as the base is near identical except for the Camera and KErnel. Did you wipe Dalvik atleast as well as reg Cache? But yeah, you are the first to report any sort of lag. As you can see from the benchmarks, this thing is no slouch. lol When I beta'ed this ROM out there were a couple things that did cause lag on the Beta but we stomped those out. It was mainly the CPU governor or clock speed (Actually being too high!). Did you add any apps that would interfere with the native governor that I put in and did you apply any of the clock speed zips?
But yeah, 2.5 was no slouch but compared to this... Not even close! lol
-Scott
Reactions: Genesiss
I did a full wipe and all appears to be good now. I'm running the default 1.6 OC setting. No other governors installed.
Is your 2900 quadrant score OC'd at 1.78? Immediately after install I had almost 2400 and 2100 after everything was reinstalled OC'd with 1.62.. I understand these scores aren't the gospel, just curious. I tried the full OC once and my phone almost exploded.
2900 was at 1.78
-Scott[/QUOTE]
ok thanks......quick question...is there a way to have the calendar show the month instead of agenda on th calendar screen? if i go into the calendars i can adjust to show month first but on the calendar screen (of the 7 we have) it shows agenda!!! Thanks for the help....if i should take this topic somewhere else...let me know....
Yeah, I dont know. May try the main forum if I were you.
I couldnt leave the benchmarks alone....
FYI...just go into calendar/settings/start in and pick month.
If you are talking about the widget, you have to change it. Remove the agenda widget and then pick a new widget. HTC calendar, then it will have a few options to preview. One of them will be the month calendar.
you rock......got it done.......thanks....couldnt stand the agenda view...appreciate the help!! :)
-Scott[/QUOTE]
ok thanks......quick question...is there a way to have the calendar show the month instead of agenda on th calendar screen? if i go into the calendars i can adjust to show month first but on the calendar screen (of the 7 we have) it shows agenda!!! Thanks for the help....if i should take this topic somewhere else...let me know....[/QUOTE]
Personally I use Jorte...its free in the market and has tons of customization options...it syncs with google and also an exchange if needed. Just my .02
Sent from my hacked up 3VO!
Awesome work Scott. You've outdone yourself. One weird issue. I can't update my profile. Keep getting error 1233. Fresh install, full wipe. Any ideas? Thanks!
This too funny, I put that error code and it led me back to a post that I made on PPCGeeks when someone asked me that question. They were asking if its normal after rebooting, rooting, etc./.. I said no it should not be.
Well, I did some more research and that issue seems to be related to Sprint authentication. In other words, Sprint is broken right now...
lol: Google this and my answer is the 5th one down "Sprint error 1233 2011" lol! Too funny. I had to use google to remember the last time I saw that specific error. Just too funny...
Getting error code 128.....anyone having that problem?
Ok looks like this is fixed now. I just tried it again and it worked as it should....
Thats not good... Look here: Sprint Community: Data Call Failure: Error Code 128
When I flashed a custom ROM for the first time on my EVO 3D, I got the Data call failure. I had to call sprint and they just had to let my phone access the network again. They didn't ask any questions about it, just said it happens from time to time. At least this was my experience. They may send the Sprint police after you for being rooted.
I think that officially makes you big time.
Iknownothin
