[ROM 10-3-12]GingerDX JB UI on CM7+Sense2/3 lockscreen
^What he said, but if the app force closes or doesn't work, you need the lib file for that app. You can get it by opening that APK as a zip file.
Sent from my HTC One V using Tapatalk 2
A v30 was release 1-20-13, would you guys like for me to attempt the port for an update, or is this Rom barely used by all of you? :thumbup::thumbdown:?
I'm always interested in getting my ROM flashing fix for the week. This looks promissing. Could you add some lock screens in a zip as well?
What do you mean by that exactly? O.o
The screen shots look promising, if this ROM has been updated it might mean added performance.
It has flashable lock screens right?
The locksreens are default Cyanogenmod behavior. It's in the settings :D
I'll try to update today, if it I don't run into issues like I have been recently. I have issues when porting from the X8 sometimes. No idea how to build from source. Wish me luck. :D
Luck has nothing to do with it.
Your persistance and determination will however.
Looking forward to seeing it on my phone.
If you need any help, let me know.
I tried flashing this and it didn't work... it said verification error
Did you try turning off signature verification?
No but usually when i do that multiple things go wrong sometimes it wont load. Like i tried one ROM that stayed at the android screen when booting up i left it alone and for an hour it stayed so i gave up on it.
Cannibal is just as good. No need to change.
Check the md5 sum of the downloads, you might have one that got corrupted. If they check out ok, then turn off signature verification and re-flash after a full wipe.
Does this allow previewing emails in the notification menu like JellyBean?
Does it include app2sd?
RangelS25
