[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Is there any way to get rid of that "roaming indicator is off" message
Sent from my LG-VM670 using two thumbs
I use beautiful widgets with weather in the status bar, which replaces that message.
Sent from my VM670 using Tapatalk
Re: [ROM][3/23/12][2.3.7]MIUIgb! By team A.P.P
I too as well have the device setting force close. Not a big issue. The percentage battery option doesn't work for me, either. Fine with me, as I like the top bar kinda sorta better anyway! :D
Great job, Gannon! :)
@Cole2KB
If you don't like the default MIUI launcher you could try QQ launcher. It's like MIUI's but with more options. I use it to add more space on the home screen since I decrease my density to 130.
theme patch isn't working for me. Unless I'm doing something wrong.
ARGH!
I'm having the same crash (phone reboots) on the USB Connect again. I have no idea why. Not OC'd. Worked before I installed my apps by Titanium Backup, and after I restored them. Then I installed QQLauncher and it started crashing. Uninstalled QQLauncher and it still crashes, so I don't think it's QQ. ANY IDEAS?! :confused:
Did anyone else notice that the browser was missing from the rom? Also the Device Settings, are there any particularly important settings in there? I had to ask because I'm getting FC's on it as well.
Sent from my LG-VM670 using Tapatalk 2 Beta-2
Seems like you got a bad flash
Sent from my LG-VM701 using Tapatalk 2 Beta-2
Um, no. Thdlese are known issues. :) Gannon forgot to include the browser in the zip. Just download Dolphin or something.
Yeah I nabbed a browser before I posted, I just wanted to point it out. Also can anyone see WhatsApp in the market?
Hmmm...
What did you guys do to the build.prop? I assume that's where the problem would be coming from... For whatever reason I cannot install Podkicker, because it thinks the phone isn't compatible with it. Bullpuckey it isn't since it installed just fine under BACKside IHO! In any case it's a podcast fetcher\player, what exactly does it need to be compatible with?
Gonna try something here but right now I'm thinking I'm going to be rolling back my nandroid to IHO again until next release. This has been the smoothest I've seen yet and I've found the launcher to be growing on me, but I gotta be able to install my apps and customize my lockscreen... The lockscreen I can wait on a bit, the apps I gotta have.
EDIT: Huh... I flashed the gingerbread gapps package (from IHO BACKside) right after flashing the MIUI R0M and now my app showed up and installed without issues. I'm thinking the gapps intergration may need some work in the R0M, because it is getting tripped up by the immediate installation of Google Play.
--bornagainpenguin
PS: completely unable to get themes to work. They download, they apply, but they do not work.
Build.prop or a missing gapps file will cause this.
oops.... <waves hand> "these aren't the droids you're looking for..."
Never been a huge fan of purple, but I'm having some theming fun today. :)
Status
dhickman
