[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
I'm more inclined to think it's a gapps issue considering the experiment I did with the IHO gapps that fixed the problem for me. Not sure that it's the R0M's fault though so much as Google's wonky Play market updates. At one point when trying things out the market listed my purchased apps as mine but with the prices listed as if I'd never paid for them...
So my uneducated guess is definitely the gapps intergration and the background installation of the new Play market.
Re: [ROM][3/23/12][2.3.7]MIUIgb! By team A.P.P
Does MMS work? When i flashed the initial release i would get the 9999999999 messages, is this fixed?
Did you say that this version doesn't theme the statusbar?
Idk. I thought it didn't, but mjs2011's pictures say otherwise.
Either way, the Chinese guy said he's fixed it but he's yet to upload it
Sent from my Amazon Kindle Fire using Tapatalk
Alright, I'll probably download the next version. I'm excited :)
Reactions: rukin5197
Yep. My status bar changes after a reboot. Just like there're cm7 theme engine.
with the new build is there still no browser?
Sent from my VM670 using Tapatalk 2 Beta-2
Huh? Lol there is no new build other than the one I uploaded yesterday. And that was the first one with no browser.
Note: Until I resize the MIUI browser, I'm most likely going to use Miren.
What's wrong with opera mobile? :-P
Seriously, any thoughts on the issues I reported a page ago? Or if some of these problems are being caused by Google Play updating itself or maybe even an issue with the gapps intergration?
I didn't make any noticable edits with the build.prop, so it has to do with the GApps integration. I must have missed a file. Sorry, will be fixed in next update.
Reactions: bornagainpenguin
No problem, I'm sure you're doing everything you know how. Any ideas on why theming doesn't want to work? I'm willing to try things to make it work, but I need to have some suggestions on what to do.
So you've tried the theme fix zip and the manually adding a folder in /data/system called theme?
Your resizing the MIUI Browser, how's it going for that?
IS there a difference between that and Miren browser?
Okay, making that directory did nothing. Was I supposed to copy a theme there? I tried that but it doesn't show up at all.
There should be a miui folder on your sd card put the theme you want inside the theme folder inside the miui folder on you sd card, that's how I got it working
Sent from my LG-VM670 using Tapatalk 2 Beta-4
I am getting 9999999999 messages for MMS. Is there a work around for this or any solution?
Status
nosrejocius
