[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Can you just upload the new version? There's enough people here willing to try it out...and I'm not even on the Optimus V xD
Not to be mean, but it is a little rude to push for a release or ask for ETA's. I know you didn't mean to be rude, but we do need to treat our dev's with a lot of respect, for without them we'd still be on crappy 2.2/2.1. :)
Re: [ROM][3/28/12][2.3.7]MIUIgb! By team A.P.P
Thanks just wanted to ask flashed for the wife this morning and now she all crazy think I broke her phone lol... ill be looking out for the update once shine thanks alot
Sorry guys but I still can't find my phone. Until I find it no further updates are going to be available. It is annoying the hell out of me that it is lost and in recovery mode.
But if someone could possibly download my 3/23/2012 version and replace Settings.apk from that into this new update and test to see if it works, that would be awesome.
Here is the link: MIUI-OV-03232012.zip
Having it stuck in Recovery mode would be a problem... Here's to hoping you find it soon! Good luck! :)
When I try to add the file to the archive I receive a message saying it's corrupt. Is anyone else gettign this error?
Corrupt - Bad Download(maybe)?
What are you using?
I was using Winrar (which I usually use) to edit the zip. I also assumed that it was probably a bad download so I downloaded it again to verify, I'm still getting the error though.
so i was able to pull settings.apk out of 3.23. and put into 3.28 booted but still no settings but this on dose now have gapps.
Yea sorry I see now how it looks kinda rude...
I'll try it right after I finish trying what I said I'll try to do with that build, I was doing dishes and had it ready forever ago, I'm just flashing it now...
Edit: I see kalena tried and it failed, maybe an odex file is needed......your LeWa version had a .odex for settings and it worked fine, I may try adding just the odex and see what happens.
Reactions: flapjack.fiasco
I totally just accidentally thanked you. Enjoy! :D
Reactions: sammyz
Alright, added browser has FCs when added to 3/23 :(
I used it from a CM7 build made for my phone
I haven't been using any of your ROMs, not for any particular reason other than what I'm running now works good enough not to mess around with it.
But I just wanted to say thanks for all that you're doing. The devs for this phone are all over the place, porting this, and building that (hell, I'm running pure IHO that I built myself right now, thanks in no small part to the devs in the OV community).
All of this is just great for our phone, and your part of what makes this possible. So thank you!
Reactions: rukin5197
i did not use 7-zip i cut and copyed it to move it over
Gannon...do u have roomates and if so are they a$$holes??? And if ur a normal messy guy...you check under ur bed lol?? (Just teasing....it actually does suck)
Sent from my LG-VM670 using Tapatalk 2 Beta-2
Lol I really hope Gannon finds his phone soon....
I tried adding the odex from the old LeWa port and no go for settings :( the settings.apk from 3/23 and 3/28 are exactly the same so there's no way that that's the problem.....
One MMS starts to work on this I might switch from IHO Backside to this since I like all the custom themes and whatnot this ROM has.
@Gannon, Are you sure the settings>about>processor isn't correct? It says I have a 725.0MHz processor, but I honestly can't overclock past 600 without a reboot. :confused:
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Status
Qbaumildand
