[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][3/28/12][2.3.7]MIUIgb! By team A.P.P
It seems as though long-pressing on the wifi toggle of the causes the status bar to close. It also seems as though the settings application is "not installed" on my phone.
The settings apk is there but the odex file is not there. I suppose that's why the settings don't work
Sent from my LG-VM670 using three thumbs
Am I the only one missing the Google store? Also, when trying to install programs from my memory card, I get a force close every time. If its a bad flash I will try again
no i was missing all Google apps had to flash gapps to install them... i am also missing system settings and the play store will not connect to data looking forward to the fix thanks.
You guys must not be running the same build I am.. this is odd.
I'm not experiencing any of these problems. But I'm going to try reflashing and reocurring the same errors.
Is there supposed to be an odex file for the settings.apk?
Yes but that shouldn't be the problem. Music doesn't have a .odex file either and that is working perfectly.
could it have been a bad upload maybe?
So everything is working now, Except mms?
And im a noob to Miui... Dont i make a folder called Theme and then i place the file into there through root explorer for a theme? :-[
Havnt flashed this yet...
Thanks
And great work!
Thanks
And great work!
i'd hold off a bit. everyone that has flashed the last update seems to be having problems that are not consistent with the results gannon is getting, which suggests that there may have been an issue with the upload.
The click through links on the wordpress blog are blank, they just display a page with the name of the rom for the section and nothing else. Am I the only one with this issue?
Sent from my LG-VM701 using Tapatalk 2 Beta-3
Yeah I went on the site the other day and all I could view was blank pages with the names. I was going to download AOKP but the blog was blank.
Sent via the Postal Service
I was wishing to release this to my optimus M thread, but the update is worse than the initial release, btw camera was working fine on the Optimus M with the initial release :D but it was probably because I ported that it works....only changed drivers, build.prop, and boot.img files....I guess I'll have to release the 3/23/12 version :'( but I'm going to fix the theme myself and add MMS fix for metro as well as a web browser.
If there's a flashable MMS fix, I can fix MMS for you guys if someone sends me a link and I need link to the original 3/23/12 as well, I overwrote mine with the port version...
I thought this update (if everything went well) was a big update.
On another hand, I need help.
If anyone notices some messed up translations,
please contribute and help me fix them!
https://docs.google.com/spreadsheet/ccc?key=0AsQkZxFY2WwadDRWZUJUZFRONzZIWlFTaWhCaVVoMEE
Sent from my Amazon Kindle Fire using Tapatalk
Status
mohamsn
