[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][3/29/12][2.3.7]MIUIgb! By team A.P.P
You should try to get the camera apk from another rom and replace it. Then set permission to rw-r-r and reboot!!
Someone posted about mi locker and lock screens can't find it any help?
I love this rom with all its lock screen and theme options but for some reason my notification sounds aren't playing. I get the text or email but hear no alert no matter what setting I use. Anybody else have this problem?
Bad flash? Or did you SET your Notification sound yet? Everything here is working fine.
Only bug I found is the Live Wallpaper, It force closes.
Yes I set it to several tones to check. Was hoping it wasn't a bad flash lol. I'll see if vibrate works and leave it alone if it does
Sent from my LG-VM670 using Tapatalk 2 Beta-4
Edit: menu,launcher settings ;) seems to help :) ill do more testing! Daily Rom!! For now;)
Try going threw your settings, works find for me sound and vibrate!! Only problem is is that it does not want to OC can someone confirm this and if it can what's your OC thanks
nice rom!! Gannon!! Thanks
Flashed 2/29 multiple times worked fine until every thing I clicked in settings force closed..was trying out a iPhone theme. But other than That great work :D
There is no split 160 for sms in the default messenger. can this be added somehow?
Yes go to themes then customize. And choose which ever one you want to change!
I found a way to get the camera by moving Miui camera to system apk then changing permissions and rebooting but no video playback,any ideas?
I have been using this Rom for a day now and everything works amazingly, I just have one problem I use a2sd to increase my internal phone storage but when I switched to this from IHO it shows that I have 9452 KB of internal app storage but I can only use about 323MB of it before I get a low memory error from the market. Is there a specific apps2sd app I need to use with MIUI? O and for the camera if you have Titanium Backup if you restore the camera apk from there if you backed it up previously and it will be fully functional. And one more question how do I take screenshots in MIUI?
Use Titanium Backup to move your apps over.
Reactions: lokito15
Status
ihtasham
