[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][3/29/12][2.3.7]MIUIgb! By team A.P.P
Use Titanium Backup to move your apps over.
That doesn't work either, tries to restore then says app could not be restore and just gets stuck until I force close it, I got over half of my app collection restored before the error happened. I tried rebooting and restarting the process and that did not work either, but thanks for your advice none the less :)
Updated OP with new link. Small update
Fixed Camera and updates will be OTAs from goo-inside.me app from now on. I'm pretty sure it will give you a notification when a new update is out.
Link doesn't seem to be working for me :/
File is not found
Ugh goo-inside.me is taking a little while to update the name. Give it a second..
If it's any useful info, it seems to be linking to Filename: MIUI-OV-03292012.zip
It's looking for the old ROM, while it was probably deleted
No, I changed the name of the ROM via ssh and it hasn't updated the website to my new name (03312012), so it tries to download the 03292012 version even though it's a changed name..
Wait so what is the difference between this MIUI ROM and the MIUIv4 one?
And everything works it's just the settings that are having a problem?
I'm going to port the new update soon :D I hope everything will work fine on the Optimus M, everything has so far xD
Hold up, so you're trying to restore your apps? I meant to use a batch Move Apps to SD. Is this what your doing? I'm confused... :)
Status
Crghjuygf
