[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][4/04/12][2.3.7]MIUIgb! By team A.P.P
Gannon, nice job on this release. Your most stable yet!
Did you get a dropbox 404 error, or was the bandwidth in his dropbox over? Because if it was over, you can copy the file to your own dropbox to download it.
Sent from my NookColor using Tapatalk 2 Beta-5
404. He said he deleted it, but most users on XDA don't check their PM's. :'(
Is MMS broken in this update?
Meant to post this way earlier, but ehh.
MIUI has a built in task killer. Hold search, then slide left when the window comes up.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Reactions: Badboytoast
Gannon, just wanted to thank you again. This ROM is running really smooth. MMS will be nice when it's fixed, but I don't use it a lot since I quit sexting.
The only question I have is if there's any was to get rid of that weird black block on the top left side of the status bar after applying themes.
Thanks again!
Thanks again!
I don't know if that was a joke or not... lol.
But I have seen that problem, and I'm looking to fix it
Sent from my Amazon Kindle Fire using Tapatalk
for the record, if mms is fixed, i may consider sexting again.
Reactions: rukin5197
so on a serious note.
does anyone go outside of the theme app to get miui themes? if so where and how do you install them?
i have looked around for a bit and did not see any post about this.... i keep getting text from a 9999999999 number and it is a bunch of BS texting is it some in the rom ? i have down loaded a stop texter to stop it for now but is there any thing else i can do to stop it. i hard about it on the Motorola triumph miui rom but i cant find it agine.
Mms is sending but not receiving right? At least mine is
Sent from my LG-VM670 using Tapatalk 2 Beta-6
Its broken in the current build. All that random txt your getting is pictures. Stick around, hopefully itll get fixed. :P
Thanks that makes since I sent wife some pick the other day and she never got them..... but what dose the 9999999999 number for?
Status
Hopluikla
