[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Re: [ROM][4/04/12][2.3.7]MIUIgb! By team A.P.P
Battery Indicator(Graphical) wasn't fully showing. But now it is. Make a nandroid backup and give it a go. I'm still on old build as well, but I just got a update notification from the Goo Manager thing. :D
on build 4/4/2012-battery percentage indicator still not working, only the default, and were's the goo updater??? everything else perfect for now,... thanks!! great job...
Reactions: MicroData
Can some one please confirm if mms is broken on the new build! Thanks also when I get the new update from the goo updater, wish I downloaded but i can't seen to find the new update! Where should i look for it? Thanks
It downloads by itself through the Goo manager thing. Just follow it?
Latest bug I seem to have:
If it's plug up via USB to a PC, it does a bootloop, AND never boots. If you take it out, it boots. :/
IDK if it's just me, but my phone is starting to reboot alot often...
:) I was working! So I let it download by it self! Then I cleared it! Thanks , then I was looking for the new download on my SD card but i still can't find it, guess ill download it from the OP!
I posted a thread similar to this issue. Gannon suggested turning off USB Debugging. I haven't tested this myself yet, but you could try it.
It still does the same thing if I don't have anything plugged up. :/
Found it! :D
Caroline HD3 MIUI Lockscreen- Port to MDPI by ~Caseyls on deviantART
@Gannon, If I try the MMS fix from your port guide, will it work?
Ha! Yup, that's me! I just finished porting over Revolte by onsomeg , just waiting for a reply as to if I can release it. Now I'm on to minimalslider, also by him. That one's proving to be a challenge though.
From the sounds of it, you got a bad unit. That's what I've gathered from your various bug reports. I'd get another refurbished from VM.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Reactions: CuriousNoob
Is there a way to find what build of MIUI this is so I can flash extended settings?
Tapatalkin' it from my IHO CM7.2'd MIUI Themed Optimus V
Has any one else noticed that the UI sounds don't work
Miui 2.3.16 :p
Btw, when using your lockscreen. The phone bootloops. :s
I've tried to look around but couldn't find it for the life of me. The chinese people aren't very specific.. Although I'm not 100% positive that Extended Settings works, even if you find the right one.
Miui 2.3.16 :p
How did you find that out?
Like I've said before, my phone must be the biggest baddest phone around. I haven't occured any reboots. It would be hard to do this, but if you could get a logcat of it right before it reboots, I could see the problem.
Could be an app.
Setting then system. Scroll down, about phone, scroll down miui 2.3.16 :)
Miui 2.3.16 :p
Any idea which one to flash? [MOD] Extended Settings Menu Options | MIUIAndroid - Redefining Android
I have no idea about the LS. Using it on MiLocker on CM it was fine. I'm going to flash this today so I'll see if it loops for me as well. I've never heard of a LS making a phone bootloop though...
Reactions: kcls
Status
ahsokacat
