[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
I'm about to flash this ROM again. I love MIUI.
btw, Gannon, my birthday is May 1st too! :D
That's incredible! I thought my birthday was unique, but it's always good to have a buddy on your birthday. Lol.
Tell me if you need any info. And thanks! I can fix it simply by adding in the old kernel, but yours would be better.
Isaac anybody getting any better speeds with this update rather than the other ones?
It seemed like to me with tvalls kernel started out fast response wise, but the animations weren't smooth. After a little bit the whole phone kinda became unstable. I know tvalls kernel is good, worked great on BACKside but I think it might need to be tweeked to fit this rom.
i cant even get the rom to boot.. and its late and im working on other stuff. ill take another look tomorrow
Is anybody getting any better speeds with this update rather than the other ones?
On all of the miui builds the moment I have any apps on the phone my memory drops dramatically from around 120mb to about 160mb, I've been using v6 super charger to make it run smoother, but using the first build you released today it seems to run perfectly fine at that amount of ram. I've been down to 100mb so far and had no freezes or close of any kind, soI'd say it does run a bit better
Gannon I flashed the 4/14 build and then tvalls kernel. This thing ran great on interactive x min480- max844, the only prob I had was no flashplayer. Great Job! none the less
Gannon, you should make it more clear.
The themes you download, when you apply them, it goes in the /data folder there for it takes room. If the theme is about 20megabytes, you lose 20megabytes.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
Hey, This isn't a bug or anything, I just wanted to thank all of the devs for putting effort, and taking time from their lives to enrich my own. I appreciate all the work you guys are doing, and I wish you the best of luck in gaining progress with your rom :D
I seem to be getting that a lot lately. Lol thanks!
So I shall be flashing this later on tonight when I get home from a friends. But my question is, is the battery life noticeable better then IHO BACKside?
My Optimus Sucks. Everytime I get a txt it reboots. And I'm not overclocked yet. :l
@Gannon, you weren't lying about the nlack on black. Its still there in small windows, but not a problem. :P
Click to view quoted image
My little brother just got a new optimus and I hope his isn't as bad as yours, because I'll be doing all the work to it (no offense). Black on black is definitely a problem. I usually get it in clock widgets and whatever. I believe AJ is trying hard on it.
Status
gurusdex
