[ROM][4/14/12][2.3.7]MIUIgb! By team A.P.P
Status
Not open for further replies.
Gannon, you should make it more clear.
The themes you download, when you apply them, it goes in the /data folder there for it takes room. If the theme is about 20megabytes, you lose 20megabytes.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
I'm not talking about the storage, I guess its called ram, its the memory the phone uses when you start an application, I had to switch back to mirage and right now I'm at 240, on miui it kept droping bellow 100 and rebooting so I had to to switch back
Tvall, maybe you can help me here (and please don't take this the wrong way), but when I use your kernel my phone become unstable, the animations are no longer smooth and after about 15 minutes straight of using my phone it becomes laggy. Is there something wrong I am doing? I have the over clock settings to 480/787 with smartass v2 as the governer
I'm guessing this rom just doesn't like my kernel. In my tests on various iho roms it reduces lag..
My settings are 122 min 600 max interactive. (My phone can't go above 600)
In the OP it says the black square is still in the top left corner of the status bar but this is no longer an issue for me at all, is the status bar theming properly for anyone else?
Up your min. Your making the CPU spike
it actually stays at 122 when idle, which is a lot of the time. even when upped it still spikes to 600, and uses more battery
Today, I unplugged it around 10, now (9:40 pm) it's at 60%
nope -_- I think it's a theme issue though, because some themes give me this issue while others don't
Has anyone tried the second kernel tvall released?
I don't know what the problem is. I can't recreate the problem myself. I can't fix a problem I can't occur myself.
Did you try wiping everything and installing instead of updating???
Maybe it was a bad upload? Try uploading to mediafire and lets see if there are different results.
I gave it a shot. Seems to run a little faster them his first kernel. I did experience some stability issues with both
I don't really know what I'm doing so don't expect anything good coming from me yet (and if I produce something useable, consider it a miracle. I'm learning as I go) I'm surprised my kernel is getting so much attention....
But my kernel isn't showing any stability issues for me on my rom. Just seems to be this one that doesn't like it
Reactions: almoser and notown
I think its getting a lot of attention because new kernels available to the public is not common here. flash addicts i tell ya haha
Reactions: tvall
Status
Nazeer zaheen
