[ROM][5.07.2011][ED01]Community Rom V1.3
ok so I'm running this Comm ROM V1.3, was using slide-it and got tired of it changing my words AFTER I had completed them and ck'd that they were correct... grr does anyone else have that problem?
Anyway I decided to go back to Swipe but the TSM on the keyboard is annoying.. I found this link in a XDA post, but I'm not sure how to go about loading it, or even if I should?
file is: swipe_fix_1.3.zip
anyone ?!
You flash it in ClockworkMod Recovery (CWM.) Click the link in my signature to learn how to flash zip files in CWM. And if you don't like the TSM on the keyboard you should flash the swipe fix patch.
Reactions: dlcullen
Or any on the awesome new swype themes gunnermike had made for us!
Sent from my SCH-I500 using Tapatalk
VERY COOL, thanks wyllic I looked around and found the swypebluev5 on the xda forums, it's great!!
I didn't realize there were diff swype themes available ;-)
I love the Fascinate forums you guys are great!!!
Awesome! I'm glad you found something you like! You can find themes for just about everything here, it's what makes AC and Android so great :)
I had this rom flashed before, then decided to try out some other ones, then when flashing back to this i get stuck on the samsung logo, does not proceed to boot animation. I tried re-downloading and flashing and still nothing. Currently im running 1.2 trying to get back to 1.3.
That's been an issue for some people. Seems to be centered around the OTB 1.4 kernel included in 1.3. Try flashing OTB 1.5 after you flash Comm ROM. Also I've noticed I've had better success getting the ROM to fully load if I do a data/cache/dalvik wipe both before and after flashing the ROM. Whatever is easiest for you, you can boot to CWM right now and try a full wipe then reboot, or you can try flashing a different kernel.
OTB 1.5 here:
http://adbdev.com/danknub/SF_TW_OTB-Reloaded_ver1.5.zip
How's otb 1.5 working for you shark if you've tried it yet. I know like me you've had good luck with comavolt
Was getting sleep of death and random reboots anytime I undervolted more than -50mv on 200-600 and -25 on 800 & 10000. Been stable running those settings in sio. We'll see what happens as I try to pump up the undervolts
I'm running KB 1.3 with white chrome theme from gunnermike...its been a great combo so far but yesterday and this morning I was gettin random FC's and reboots wit OTB1.5 so I went back to 1.4..however while I wasrunning 1.5 and now also on 1.4 my screen will no longer rotate. I did wipe both caches before going back to 1.4. I'm not sure what I may have done wrong...thanks again for the help....I love AC!!
I'm running stock voltages for the time being I'm going to see if it fixes my problem with plants vs zombies
I had unfavorable results with comavolt, so I flashed OTB v1.5. My voltage is:
noop limit 1200
1000 -25
800 -50
600 -25
400 -25
200 -75
100 -100
Cpuspy says nothing higher than 1000 is being used and being unplugged for 11hrs I'm smooth as ice and at 36%. Light/moderate usage. I'm satisfied. Much of my usage is texting, but some browsing and games; pogoplug stuff.
Have not had a single crash or FC.
My phone talks to computers.
Lol that's a big fat nope, still getting the same problem with the game, which really is unfortunate because it rocks!
return it and get your money back! woops it was free. I dont think that game is that great anyway.
I just loaded the new PBJ Kernel and none of the blue letters flashed on my screen but it told me it was successful in recovery.... true or false?
Ninjja
