Ok. For some reason there seems to be a ton of confusion on how to get certain apps back if you don't like the themed ones in this rom.
All anyone needs to do is open up the ZIP file of a rom, (I recommend sc2.9.2 as it has everything people have been asking for) navigate to system/app in the zip, and extract the corresponding .apk for the app you want. Next, just copy the files you've selected to your sd card and with a root file explorer, move them to /system/app on your phone.
Here's a list of the ones people are asking for most:
Mms.apk - messaging
Vending.apk - market
Screencapture.apk - built in screen cap function (back + power)
MusicPlayer.apk - stock player that came with the phone (works with car dock)
DialerTabActivity.apk - stock phone dialer
LatinIME.apk - android keyboard
AxT9IME.apk - samsung keypad
If youre having trouble finding others, as sometimes the file name doesn't correspond directly with the app name, post back here. Ill try to keep up as best I can.
Sent from my SCH-I500 using Tapatalk
Mms.apk - messaging
