[ROM][5.07.2011][ED01]Community Rom V1.3
First, if you have launcher pro set as default when you press home button, clear that in applications and use the launcher included in your ROM (AOSP)..then go into your app drawer and see if the missing apps are there..if they are it's probably lp..
Then..go back into LP.. (hit home key and select from list)
Go to preferences..
Make sure you don't have them "hidden" with the LP feature of hidden apps. I would check that
If that doesn't work...and your willing to reset up LP (depending on how many tweeks you got going) I would go into applications and clear the LP data and cache.. and recheck..
Still no go... go into your file manager and see if the .apk files are there for the app your looking for..if not redownload..
Unless my phone was doing some crazy stuff - none of that should be the issue. I haven't been hiding apps, they're all still there in the All applications area. I did just clear the phone's cache and dalvik, and it happened to work. No guarantees that it came from doing that, as they've all been gone before and then upon another restart showed back up. I may try to clear the LP cache like you mentioned since I don't have a lot done as of right now. Thanks for the help. And as of right now, I have a full app drawer again.
sometimes a simple reboot fixes this as well... try that if it happens again
I did about 5 times - and it wasn't working. It has worked in the past though - you are correct about that. That's why I posted it - cause it wasn't working. Thanks, man.
One more thing though - could someone explain the SMS / MMS add on to me. Is all the add-on for color changes or does it affect what is sent / received. I just know - I hate how pictures come in as videos some times. What exactly does the add-on do? Thanks in advance.
Hold down volume up, volume down, and power buttons until you see samsung logo flash for second time. As soon as you see samsung for second time, let go of all three buttons. This will boot you directly to CWM. Scroll to mounts and storage, make sure it says unmount in front of the top four - system, data, dbdata, & I can't remember what the 4th is. Then hit menu soft key to go back one page, scroll to advanced, power button, scroll to fix permissions, power button, wait for it to finish. Menu soft key back to the main cwm page, power button to reboot. See if you get FC.
Look up in the sky! it's a bird, it's a plane! It's Landshark?
Sharky, pick off the attached file before the mods get me. I think you'll like it
Mike
What does this app do that's different from the community ROM?
the sms.apk is just the sms app from superclean 2.9 where I said to pull it from. the system/app file is just the folder on your phone. I don't understand your question.
I rooted my phone awhile back and decided its time to upgrade to froyo. My current setup is:
Hardware version: i500.04
Firmware version: 2.1-update 1
Baseband Version: S:i500.04 V.DL09
Kernel version: 2.6.29
Build Number: SCH-I500.DJ05
I read a good number of pages on this thread and the first step was to get back to stock DL09 before i flash ED01 modem and i was wondering how to get back to stock DL09. Any help would be appreciated
Mike
I will have to wait until I get home to check that out. Work computer has software blocking a lot of stuff.
I have found an issue.. when using the dialer a lot of times I just start typing the name of the contact that I want to call such as "Dad" or "Julie". Prior to installing this ROM it used to display the default number for that contact with a dropdown arrow where you could choose a different number such as mobile/home. Now, it displays only the default number...there is still a dropdown arrow but when you push it you only see other contacts that could possibly meet your criteria. It does not display other phone options for your intended contact.
If I start dialing an actual phone number instead of a name it finds the correct number but I don't have all of my contacts' numbers memorized so it would be nice if this could be fixed.
with your baseband being DL09 and build being DJ05, you are basically already stock DL09
Reactions: phommk
So I rom'd this yesterday morning. Since then I've been having pretty (what I consider) serious data connectivity issues. It seems that if you hide signal strength for one that kills your data connection. I tried hiding and un-hiding several times to make sure it wasn't coincidence and I had no data every time it was hidden. I've not had it hidden since I discovered this, but problems still persist. Nearly every time I open an app that needs data connectivity, it errors saying there's no connection. I also can not upload photos to FB. I've wiped cache, power cycled the phone a few times over the past few hours and the problem still persists. Anyone else having issues like this? Sorry if this was covered in a previous post. At work and I don't have time to read all 60 pages lol
So I think I found the root (HA! Get it?! The.. the root!? *cough*) of my problem. I first cleared davlik and partition cache and re-flashed community rom on top of itself. Issues persisted, so I dalvik'd and cleared partition again, flashed to Super Franken Clean 2.9 and everything worked just fine. I then flashed jt1134's most recent voodoo kernel on top of that and the issues started again. I also dalvik'd and cleared partition cache prior to each flash. I'm not sure if I'm doing something wrong when it comes to voodoo, but I think when I get home tonight I'm going to RTS and start fresh and see what happens.
so i should just backup all my stuff then flash to ED01 using odin correct?
You cannot flash this community rom through ODIN, you have to flash it through CWM. You can only flash the Debloated/Deodexed ROM through ODIN currently. Either way you will need to also get a copy of the EC01 modem and flash that through ODIN, and as far as the ED01 Debloated/Deodexed ODIN files, you have to use the one that wipes data since you are coming from an Eclair build. If you flash the EC01 modem in ODIN, then the community ROM through CWM, you will have to wipe data, cache, and dalvik cache in CWM before flashing the ROM
EC01 Modem:
http://adbdev.com/danknub/ec01_radio.tar
Reactions: phommk
What I was trying to ask is.. what does the SMS app from 2.9 do that's so great people want it back?
I don't recall what the SMS app even was.
I got confused. I thought you were the person who originally asked the question. Someone asked how they could get the sms app from superclean 2.9. I don't think it is necessarily all that better, I think it has more to do with the coloring of the sms app in the community ROM.
I have CWM 2.5.1... It's red.. And I'm running this Community ROM. Was I supposed to upgrade to 3.0? If so, where do I find it?
The Community Rom is running just fine, but I didn't know if I needed that version of CWM.
theantithesis
