[ROM][5.07.2011][ED01]Community Rom V1.3
Man that thread us getting long! Anyway I've stopped getting notifications for kik and word feud. Notifications are turned on so could this be a problem with the apps or the rom? Love everything about this rom so far keep up the hard work.
Data point..My Wordfeud notifications are working properly after the install.
LOL with the battery mine is so bad...I do all the right precations and took phone off charger at 7:30AM at 100% its now 11:05 and im at 63% already. Ive come to terms with my awful battery, and just need to be with my charger at all times!
if you have crappy signal strength your battery will get taxed much more.
yah i know, mine is always switching back and forth, I may call verizon and do the Data switch on/off thing. worth a try I guess to see if it helps the battery.
I am sad to report that battery life still sux! I wiped batt stats a little over 3 hours ago, after a full charge while the phone was off, booted into recovery to wipe and been running my phone ever since. Restored some apps, talked on the phone for 10 min, nothing too taxing. My battery is now down to 73%. This is the ONLY time I miss by Blackberry. I could go days on a single battery charge.
Once you wipe battery stats, it will take a few charge cycles before you actually notice an improvement. Wiping the stats means the phone and battery have to basically "get used to" how you use them again, and that can't happen immediately. Give it a few days before pass a final judgement
And once again the broken record that is me goes round and round and says this yet again for I don't know how many times..........You will most likely not see any immediate changes to your battery life using the batt stat method. It will take a few full use and charge cycles before you see any improvement. Likely at least 2 or 3 days. Expecting immediate results in improvement in battery life is like getting on the scale, running around the room 2 or 3 times then getting back on the scale expecting to see you've already lost 5 pounds.
Thanks Kevin. You're the man
Reactions: Lttlwing16
Is WIFI tethering okay to use in this ROM?
Is WIFI tethering okay to use in this ROM? Working and not reporting back to big red?
Just like everyone else many thanks go out to the Developers! ;)
Does anyone else have issues with thier 3G randomly turning on and off? I dont think I had issues when i was on 1.1 (but i was only on there for a day so i might have not just realized it). Just noticed after i loaded 1.2 last night. I have the ED01 radio
For some unknown reason some people's 3g service was affected by yesterday's 4g outage. You may be one of the ones affected. Check out codered18's reply in this thread for a solution:
http://forum.androidcentral.com/verizon-fascinate/79606-ec01-ed01-unstable-3g.html
Zzzzzzz.....
Shark, shark...WAKE UP! thank you.
You have any progress with the Odin loadset? Just wondering..
Also, did you try the Landshark ringtone?
Mike
Another Round Fired from Tapatalk
Been averaging about 3 hours of sleep a night between heavy workload at work, answering questions in the forums and PM's, and running into problems getting the KangBang ODIN packages to work. I'm doing the best I can.
Reactions: jampot
Lando, you are a superhero! :D
I noticed your posting times last night (I mean this morning). I'm definitely in no rush for the ODIN package, just curious. I honestly don't know how you run on hours of sleep.
Take care.
Mike
Take care of yourself and get some rest.
Do I have to do anything special to install the desk clock? I downloaded the apk and tried installing it, and it fails.
as for removing the themes... if you don't like it, boot to recovery, wipe cache and dalvik, reflash the rom and the theme should be gone
That's what I thought, but what does that look like with these patches? Flash 1.0 again, and go through the patches or is just the patch good enough? Thanks for the help.
you would need to reflash the patch as well... (just 1.2 since it contains everything in 1.1 also)
But since I'm never wiping data, does that mean that all my apps will still be there. I'll just loose things like homescreen setup and preferences and stuff? Thanks, guys.
Has anyone else had flash player issues since 1.1 ?
I can't get hulu to play vids right now either. Wondering the same thing too - been asked a few times, but no one has answered that I know of yet. Anyone? Thanks in advance.
Figured I'd bump this for you - been about 12 hours and a few pages. Hope that's exercising enough patience.
You won't even lose any of those flashing just the patch.
Tried to flash the Nuance_Froyo package to get voice commands back for Bluetooth. Nothing but force closes after trying to use it after pairing. Anyone else having this issue??
Does anyone know if wifi tethering is working in this ROM and if so does it report back to big red?
RohitPatidar57
