[ROM][5.07.2011][ED01]Community Rom V1.3
my status bar is really really jacked up. 1.3 installed fine but on first boot i had no clock, rebooted again and now i have a clock but nothing else...hm......
Did you check the settings within TSM Parts? There are options to hide/show the clock, battery etc. Make sure you have them checked/unchecked as you want. That may fix what's going on for you.
ya double and triple checked. just reinstalled 1.3 seems better now
Is the problem where third party app lockscreens no longer work proper fixed yet in 1.3? (e.g. - In poweramp, the lock screen direct unlock no longer works properly, I have to go through 2 lockscreens to unlock now)
I'm having the same problem with the status bar.
When i flashed it initially it was fine. I then flashed Comavolt and no battery percent patch and everything in my status bar dissapeared, I checked all the settings and nothing was wrong, it was just not showing.
I just reflashed 1.3. This time i'll flash no battery perecent, reboot, then comavolt. And see if or when the problem occurs.
Has anyone done a data wipe and then flashed the 1.3 version? If so, did you have any issues after boot up? Wondering if a data wipe reduces or even eliminates some of these issues everyone is reporting...
I had issues with the status bar as well took me changing the settings a couple times and 2 reboots but it looks like it is working now.
Shawn
i narrowed the status bar problem to the no battery percent addon. just did a reinstall of 1.3 status bar was fine. then installed no battery percent and status bar was jacked. id stay away from it for the time being.
I'm having no problems with 1.3. It's just flashing things on top of it seems a little unstable.
I did what I said before. I flashed 1.3 and rebooted (everything okay). I then went to recovery flashed no battery percent patch and rebooted and nothing in my status bar again.
I then reflashed 1.3 and everything was okay again. Went to recovery to see if Comavolt kernel was going to do the same thing, flashed it, rebooted, and now I'm just missing 3g data. And yes my data toggle is on.
I then just rebooted my phone and I had 3g back and everything else. Very weird.
Yes i agree. I would stay away from flashing no battery percent too.
I flashed with out clearing caches and didnt have any LP issues...Thus far at least and i have already flashed a new boot animation. Dont know why this is happening with some of you. (knock on wood)
i'm trying to flash comm rom 1.3 and i've downloaded it 4 times and when i try to flash it it aborts every time. someone please help
It says in your nick that you are still on SC 2.9, is that true?
If so, you have to flash commrom 1.0 then 1.3. 1.3 is a patch (from what I gather) and not a full on ROM.
If you do that you should be fine. If you nick is just outdated, forget what I said
For those already on Comm ROM, I would imagine they should be ok with just a wipe of cache and dalvik. Any problems after flashing though will probably require full wipe.
Nevermind my last post, I made a false assumption try this since your having issues
Shawn
Ah alright, definitely strange stuff. Glad you guys seem to of got it narrowed down.
I think it has to do with the sbrissen/tsm mods. Unless the patch SPECIFICALLY states that it is compatible, the icons in the status bar do not appear to work. From my testing this morning, the best thing to do it do a titanium backup, wipe data/reset, and then flash 1.3 via clockwork. This makes everything work the best without just getting the luck of the draw. It does work sometimes without a full wipe, but this seems to be the most stable.
The only theme that appears to work is the new white chrome that was released this AM that is specifically made to work with this. Also - make sure that you are all changing the font color - it is black by default and a black font over a black status bar seems invisible (imagine that). Hope this helps a few people out.
No I'm on comm rom 1.2 I just haven't updated my profile. So why if 1.3 is a patch why would it be 170mb ? 1.1 & 1.2 are patches and there only like 35 mb. I've tired to flash it on both of my phones and it keeps aborting. Is it maybe that I have white chrome as my theme?
So what's the verdict on the status bar issues? I was getting them too, even without trying to flash the EnV theme over the top of it. And I did try in the TSM settings, nothing worked for me, went back to 1.2 til it's figured out.....
Yes I did the data wipe from CWM prior to flashing and I am not currently having any of the issues I have read about so far.
Its a full rom. Clear your caches 3 times each d-cache and cache 3 times each. makes sure rom is 174,129 after downloaded. than flash it. Hope that helps
Reactions: drinkhere
ElementOrganic
