Lttlwing16
- Mar 5, 2011
- 760
- 172
- 0
Yep if there wasn't a kernel you should be ok.. There isn't any real reason to go back to stock edo1 though..
Ibrenes, I just tried this out and didn't have any issues..
There may be a bug with the Rom and Google Sync..I have sent some logcats to adry so he can look things over.
Some fixes in the mean time would be to try to clear your calendar data...redownload and reflash the patch..then resync your data..
The tw calendar is themed with this rom..should be black..if it looks othewise, you probably have a remnant from an old theme, or Rom and need to either reflash your Rom or try wiping data.
If you restored calendar data from a backup app, like My Backup Pro, or TiBu that may also give you problems.. I had issues last night when restoring app data from mybupro.
Unfortunately, the only fix for that that I now of is to wipe data/fr in cwm..
Good Luck!
He's refering to a theme. It wouldn't change your Rom, just the way it looks.
It's completely reversible by creating a backup in CWM prior to flashing the theme.
hey bigjobber...
I know you said you use handcent messaging, right?
Have you had any issues sending picture message after flashing KB?
I poked around a bit and couldn't find a solution. I don't have the Spanish language available as an option for my Swype Languages anymore.
Any way to add it back in? I did a quick search on the Swype website and didn't see anything there either.
I'm not fluent, in Spanish or Android, though I like to speak a little of both now and then,,,,
If I can sneak my wifes phone out of her site for a bit, maybe I can dig around in there a bit.
Running CommRom 1.3 with the Black Alien Honeycomb Mash theme.
nah i havent had any issues with mms. Sometimes it just take a hella of a long time to send. like forever. Only issue i have with it now is that after flashing nitros theme I cant see names of people i want to send to when i start to type there name out cause the color is black on black. Thats my only gripe about his theme as well other than that it is awesome btw.
hmmm... mine dont seem to be sending at all....
do you have to have mobile data on? Or is just wifi ok?
Yah the black on black is really annoying and happens with email as well. Data works as well to send them.
