Lttlwing16
- Mar 5, 2011
- 760
- 172
- 0
If you really want to watch this ROM fly..go into TSM---General---and change both kind of animations to FAST...wow it moves fast.
No prob man, better too much info than too little!
I have sprinklers that do that for me =) but stupid MyBackup Pro can't seem to "find" my backup even tho I can see it in root explorer... sigh
Wouldn't it be faster just to turn off the animations all together?
So can I uninstall de Adfree app since this rom claims to have an ad blocker built in?
Give it a try and let us know : )
Thanks! I'll just manually delete all of the pictures/videos off the card after copying them over to PC.Your external sd card has nothing to do with your phone's function. It's simply a storage media...shouldn't effect your installation at all. If you want to clean files off of it, just remove them with your pc..I am not sure that sd card formatting is your external sdcard..it could be the internal one..I would steer clear of that..
And I have the same problem..trying a reboot then trying again..did you have any luck?
EDIT: I figured this out...you have to move the rerware file from the /sdcard/rerware to /sdcard/external_sd
Mine is restoring now.....somehow the rerware file got moved out of the proper folder..?
If I go the route of flashing the ROM (1.3) then doing a data/factory reset, do I really need to go back to stock and do all that other OTA update stuff? If I do a data/factory reset, won't that remove traces of other ROMs and themes for me?
Just wondering.
My initial reaction to 1.3 is "very nice" Still a lot to do..but so far so good..Camera crapped out first go around, but it rebooted itself and worked the second time.. no biggie...wonder how you go back to this awesome deep, deep black wallpaper and background after you change it...I remember with 1.2 I couldn't find how to reset the background to the stock darkness..
I have the same question. I've looked through the phone and can't find a way of reverting back to black without a reflash of the ROM or just making a black picture myself and applying that.
So I keep reading that we need to wipe after we flash the rom? I just wanted to check because it seems like that goes against what we have typically done in the past with roms.
I was on 1.2 and wiped cache and dalvik and just flashed 1.3 over 1.2 and so far so good.
Hi there, this may be above my pay grade but is there a way to replace the battery with the circle battery percentage?
