[ROM][5.5.11] BAMF Remix 1.6 - NOW IN ROM MANAGER!
Also, noticed a battery increase on 1.6.2(was using 1.5 prior to)
Sent from my ADR6400L using Tapatalk
Stupid question, I always go to the remix version of Bamf. Do I need to flash the new base every time or can I just flash the remix patch?
if you are going from 1.6.1 to 1.6.2, for example, you don't need to reflash 1.6 to do so.
wipe caches tho
I guess I should clarify. Whenever a new base update is released for example 1.6.3, a remix patch follows shortly after. Do I flash the new base update first or can I just flash the remix update?
Sent y ADR6400L using Tapatalk
I have a quick question for some reason I don't have the power controls in the notification bar, the 6 signal bar, and the extra options in power options I've reinstall a couple of times and they still don't show up can some one point me in the right direction thanks
rosie setting not working
I notice on this Rom that the personalized launcher at the bottom of the screen was removed and replaced with the browser icon. When I click on it, the personalizesettings from sense still opens. I switched it to browser in the setting but it won't work. Does anyone know how to get it to actually launch the browser?
The remix version is different from the nte (not themed) versions of das bamf, so if you are running (ex) 1.6.3 nte, you will need to flash 1.6.3 remix after wiping caches and (probably recommended) a data wipe (to get optimal results) - that's because the remix is not a patch, it's the whole rom themed over.
just to be clear - 1.6 had two patches, 1.6.1 and 1.6.2 - but neither of those were remix patches, they were updates. 1.6 remix had it's own release and remix patches (updates), and now 1.6.3 release (nte and remix) are both full rom flashes, and not patches.
hope that helps. i might be more confused than you are ;) sorry if i'm way off from what you're getting at.
Reactions: Chillerman
Rosie settings in your app drawer
I have tried that and it still doesn't change it. It could of been something i didn't do when installing the Rom?
I dont think so. After you remapped the rosie button did you reboot the phone? that might do the trick
Additionally, i dont use sense as a launcher. I use adw ex (paid version but the free version is very good). You can put whatever you want in your dock and then some.
Sorry for the confusion, you have answered my question even though I worded it poorly. I guess all I needed to know was if the remix roms are standalone without the need to install the nt roms first. It is obvious to me now that they are. Thank you.
I rooted on Sunday night and it was great. Battery life was amazing yesterday. However, today my battery is draining faster than ever. My phone has been unplugged for about 3 hrs and I'm already down to 86%. I've sent 2 texts and read 3 emails. Any ideas?
I've tried flashing this ROM 3 times, and it keeps looping at the white screen with green "HTC".
I have no clue why it isn't working, I've followed every direction to a tee
Ok... how long is the bolt sitting at the HTC screen? And where did you DL the rom?
I DL'd it from the download option in ROM Manager. It'll sit for about 3-5 seconds, vibrate, reboot, and repeats.. I even tried letting it set, thinking maybe it would load and after close to 5 minutes, I pulled the battery, then did a restore from my nandroid backup.
Ok. Since you have a nandroid in hand. Try flashing. If it loops again. Try powering down and rebooting into recovery. Try a reboot from there. If that doesn't work. Head over to XDA and DL the rom from there. Gimme a min and I'll link you ;)
Tried those options, your xda link may be the way to go.
Thank you much!
ahsokacat
