[ROM][5.5.11] BAMF Remix 1.6 - NOW IN ROM MANAGER!
BAMF Remix v1.6
FEATURES:
INSTRUCTIONS:
DOWNLOADS:
is that a widget on the home screen where it says sixty three charging?
New theme boys and girls
thatdudebutch
Okay guys, now that I spent most of my free time this weekend mucking around in our frameworks, it is time to release the beta version of Matte HD for you guys. I hope you enjoy my hours of piddling.
This theme is framework only right now, and I'm not even totally happy with it yet. In the coming versions I will be reworking the status bar and pulldown, theming more aspects of the UI, Dialer, etc. As always, it's up to you guys to weigh in on what direction you would like this theme to go. More color, less color, etc. Just let me know! The best feature so far of this theme is the modded AOSP lockscreen. I reworked the xmls so that now the AOSP lockscreen background image will be whatever is default_wallpaper.jpg in your framework. To get the effect pictured above I made a wallpaper with a transparent rip through it so that you're homescreen wallpaper shows through which creates a great effect. I also nuked all the text besides the clock. I will be posting a tutorial in a day or so as well as a PSD so that we can make different lockscreen images and use metamorph to quickly apply them.
Theme Includes
Power Toggles
4-in-1 Reboot Options
Modded AOSP Lockscreen (Changeable wallpaper, carrier and text deletions)
Accurate Battery
Square Menus
Themed UI
As always, any support is greatily appreciated, look for more from Team BAMF real soon.
Download Matte HD v1: Multiupload.com - upload your files to multiple file hosting sites!
NOTE: Remember, to enable AOSP lockscreen via BAMF Toolkit to use the new features of this theme. This theme is compatible with all BAMF versions.
Next Version: Dialer, made from scratch power toggles theme, more UI enchancements, etc.
Reactions: zero neck
Stock Widgets
Can someone tell me how to get back all my stock HTC Widgets? I wanted to still use some of them and they are not listed when I go to add a widget.
ok guys maybe a silly question, but i DL the new unlock screen theme on the xda site and installed. Question is how do i get it to show up now? i have yet to really mess with mods since i am just now comfortable installing roms and radios. Thanks guys.
Try looking in the bamf toolbox. I can't remember the option name but I know there's one there to disable sense lockscreen. It may be selectable from there. If its a zip file then my best guess is it needs to be flashed via cwm
yes it is a zip file, and i actually did flash in cwm. I figured it would just automatically run onced installed. I will give what you said a shot and see what happens. Thanks for your help!
That's a little odd that it didn't pop up for you as soon as you rebooted after flashing. Let me know if it works or not. I'll do some digging around to see what I can do to help out. Good luck until then
that new one from butch i think? posted on the xda sight. i guess he is contimplating making it the stock unlock screen. the cool one with all the blurry taillights on a freeway.
not working for me either :(
To be honest I like the stock sense lock better than that one. The wallpaper is pretty cool though
Did you guys clear your cache and davlek when before you installed the lock screen, because it works fine for me.
Here is a link to the wallpaper, it doesn't come with the lock screen.
Just make sure you don't have the lock screen and were looking for the wallpaper because, uh, someone I know, umm did that.
Here is the wallpaper:
Highway with Taillights
Can I flash directly from the Das Bamf 1.6.3 nte to [ruu][rooted][MR1 aka OTA] CONFIRM Build Number: 1.13.605.7 Baseband: 1.16.00.0402w_1?
New to rooting and not too sure the custom rom is for me. Also, battery life is atrocious.
sonamsing09
