[ROM][6/26/12] CyanogenMod 9 - Official Nightly & RC Builds!
Anyone else seen this in CM?
Sent from my Galaxy Nexus using Tapatalk 2.1.3
Here's another setting I don't remember seeing in the lock screen shortcuts
Reactions: zero neck
I'm using the Cobalt theme now to :)
Re: [ROM][5/30/12] CyanogenMod Nightly Builds - OFFICIAL!
Updated the OP with the posted 5/30 builds. Anyone notice that the filename date is always a day behind the posting date?
Reactions: NotJustAPhone
Yup sometimes except the 2nd one in the list matches the date (5/29) :)
Lol its my job to notice stuff like that
Meh I'll fix it if I messed it up lol
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
I'm currently using CM9 and I've had a few problems, wondering if anyone can help me out. First, the profiles aren't working as intended. When I switch from one profile to another, it doesn't always change all of the volumes. Sometimes I have to switch a few times in a row to get it to actually switch correctly. I'm thinking this might be something that doesn't just affect the built in profiles because I've tried a few different profile apps and I'm seeing the same issue.
2nd - I'm seeing very poor wifi performance. Sometimes the speed on wifi is normal (I'm doing speed tests on my phone and the wife's phone to compare). Other times, it is terrible. I've found that if I toggle airplane mode on and off, usually it will fix the problem. I've experienced the same problems on mutiple different nightlies.
Usually, I do a factory reset, wipe cache and dalvik cache before I install the ROM. I don't restore any settings or apps, but in some instances, I have used the Google restore feature that restores all of the apps you previously had installed. I'm not sure if this has contributed to the problems I've been experiencing. Someone, help!
Anyone having issues with the mirrors? I tried to download the new nightly and it errors out. This has been happening all week and I noticed I usually can't get it until mid afternoon
It just started downloading and it's CRAWLING.
Glad I'm not the only one. Can't get it via rom manager or the website
I've had no problems with wifi and I toggle it on right when I get home. I can't speak for profiles as I haven't tried them
Hey guys it's been a while lol. I was just wondering if cm9 or any roms for that matter have incorporated the official 4.0.4 yet debating whether to try the ota or hold off for developers to incorporate it.
Every rom worth looking at has been based on the 4.0.4 source for months. Choose one, then flash the new radios and you'll be good.
So CM9 is on IMM76I and it's been on 4.0.4 for quite sometime. Does this mean anything that IMM76K isn't incorporated?
Yes, although there may not be much difference.
donbradman56789
