[ROM][8.16.11][ODEX]EVOlvedROM r3chargeD RC1 "Just Another S
This happened to me a while back on another sense rom... go to settings>about phone> network> and see what mobile network type says... it should say CDMA - EvDo rev. A.... if it says CDMA-1XRTT let me know I may have a fix for you
I have this problem. Will you share the fix with me please?
Ok first you need to know your msl number. If you dont you have to download MSL reader from the Android market.
Once you know your msl number go to the dialer and type ##3282# go into edit mode enter your msl number and then click on evdo... where it says preferred mode it should say automatic... if it doesnt... change it to that... reboot and your 3g should be back...:cool:
It says CDMA-1XRTT. What to do ?
I can go in and change it to automatic but when I go to restart it switches it back. What's going on
Something is definitely weird in your case... You might have to call sprint and see if they can update your prl and profile... just don't tell them you are rooted...
I got it to go through, you have to remember to hit menu then commit changes, but thanks. Can anyone go over overclocking this system for me?
How is the battery life on this ROM? I'm currently using SHOOTER RLS1 and I love it but it does seem like a lot of others like this ROM but I'm only interested in ROMS that have a good batter life and SHOOTER is doing pretty well so far.
the battery life is decent as I believe he's using lithid's Kernal, but I installed Golden Monkey by netarchy using the Kernal Manager from the Market
Battery life is doing well for me, but I just flashed it this morning. Used it most of the day, and still have 41%...I wouldn't have got that out of a stock ROM. Plus it looks badass!
r3chargeD also leaves a LOT of room on the phone. I went from 150MB free to 270MB. I can't say enough about how much I like this ROM. The Dev really spent some time on this one.
Just a quick note - I have FINALLY rooted my EVO this time around after Gingerbread (wanted to before, never did, then had to wait...) and this ROM is my first experience with what custom setups can do and I just want to say to the dev and to all who consider rooting - this ROM makes me THRILLED to be rooted and I can't wait to try out others!! This will always be the one I remember having first and I have even flashed an image of it so I can go back to it...thanks again so much for making my rooted experience awesome!!
I tried this rom, I really liked it but it had some definate quirks and some unstable points (display mostly) went back to older version. Will friendly try again when more stable. Just my .02.
Anyone else having issues with force closes? I keep getting "The application Google Services Framework (process com.google.process.gapps) has stopped unexpectedly. Please try again.
sukarisw08
