[ROM][8.16.11][ODEX]EVOlvedROM r3chargeD RC1 "Just Another S
Did you download the latest ROM ? Someone posted it 2 pages back .
Sent from my PC36100 using Tapatalk
Help, After flashing my phone insists on going thru android process force close. How do I get out of this nightmare. My phone is not working
Redownload the ROM on your pc and put it in SD card . Then boot into recovery. Clear cache , data , boot , davlic cache . The install from zip and it should be fixed .
I'm loving this ROM! Fast, Sweet and Stable!!
Now this is a ROM. ;)
installed easy, market was wonky at first but I figured it out. I feel like I have a new phone! Amazing.
Yep this ROM is perfect sense I flashed stocked notifactions
After about a week and a half or so im having many problems with this rom. The battery is draining faster than ever before. Everything is running VERY slow, fixing permissions helped this a little. Every time I hit search and type something in, I get a force close from Internet and to do it twice every time I want to search for something. When I mount my phone as a disk drive it says no SD card found. When I go to settings and applications to uninstall something, the numbers start spazzing out. When I use the camera the brightness gets set to the highest setting after I close the camera. I change it back to where I had it and it just keeps going back every time I turn the screen off. Dont think this one is rom related... but I partitioned my SD card and didnt know that it was also going to format it during the process and I lost everything including my original back up so I cant go back to stock now.
Well idk what's with your phone I have had this ROM for 2 weeks everything works fine . Now the SD card number spazing I get but after a sec it stops and works fine . Download a differnt ROM and flash it
Sent From my Evoled HTC EVO using Tapatalk
I just went back to a stock-like odexed rom. My battery life is significantly better. Everything is much smoother and faster. No force closes. One thing I would like from this rom is the keyboard. The stock one kinda sucks for my fingers. Anyone have any idea where I can download it?
flashed this on mine and my friends phone, He got 5hrs on his if he was lucky and i got 6-8 how the heck do you get 9hrs with it being only on 81%!!!???
When normally they test it that have different stages of test for the battery , 1 performance , 2, moderate use , 3 no use at all . Most likely he didn't use it at all and got 9 hrs out of it. Me i flashed poon kernal and the battery is exceptionally good i can get a good 12hrs moderately using it when i am not using it i can got 2 days not even touching my phone before it tells me to plug in the charger .
Awesome ROM, been using it for three days now. Does anyone else have any compass issues with the ROM or is it just my magnetic personality/pacemaker?
This ROM is the ****!!! The way these ROMs are EVOlving for the EVO,I am in NO RUSH for another phone.
Keep up the good work developers!!!
Were can I get the stock notifications zip ? It was on here before but now I can't find it and I deleted the zip file off my SD card for space .
Tfunz
