[ROM][8.16.11][ODEX]EVOlvedROM r3chargeD RC1 "Just Another S
Hmm none of my widgets are working , is there any fix for this ?
Sent from my PC36100 using Tapatalk
Great ROM when I first flashed it, but now I'm having the weirdest problem: When I make a call or receive a call there is no audio. I can't hear them, they can't hear me. The phone may also be dropping texts (both coming in and going out), but I'm not sure about that.
I'm going to try reflashing and see what happens. I'm seeing a lot of chatter about particular kernals. Can someone give a tutorial on 1. what they do 2. how to change (before flashing, after flashing, anytime, etc.) and 3. a list of some of the ones people like and were to find them? I know that's asking a lot, but if you are willing many of us will really benefit. Thanks!
So far I love this ROM. Battery drains a little fast but its very powerful. I'm blown away
I tried to give the "Final" version a try last night, and I cannot get it to install on my phone. The installing bar gets about halfway, and it says installed. Reboot, it loads, and when I open the lockscreen, the phone freezes to the point of battery pull. I was thinking maybe something wasn't getting wiped, but then I wiped everything again and installed the RC1 version again, no problem. I wonder what gives...EvolvedROM's and MikMik ROM's in general are great.
Anyone know why "Barnacle wifi tethering" app doesn't work on this Rom? Not only does it not work but it kills the data signal and you have to reboot phone or update prl to get it back
Well I know on mine it did that but all you have to do is wait it takes a few mins at first but then it starts working .
Yea, I waited like 20 minutes...I also tried the 1GHz fix thinking it might have been the built-in overclock and that wasn't it. I didn't check the MD5 sum, but I might have got a bad download. I'll try it again someday. I'm plenty happy with RC1.
I'm not near my computer but would really like to flash this rom. Is there anyway I can download the zip to my phone and go from there? I flashed my first rom through rom manager.
You can download to your phone, then use root explorer to move the file to the root of your SD card, (out of the download file). Go to recovery, nandroid backup, wipe all, data, cache, dalvik cache. Return to menu, then flash zip.
Personally I stopped using rom manager, and do everything manually. Also if your not already using it I would suggest using Amon RA recovery, it can b flashed through rom manager. It seams to be better at wiping than cwm, IMO.
dammit Jim I'm a roofer not a doctor...
It's gonna take about 5-10 mins to download. Just a heads up. But the method described above will work
I'm not familiar with root explorer. :( Right now I'm downloading it to my computer I finally got home and can do so. I'm going to do it that way and use Amon RA recovery. Fingers crossed and thanks!
Have been running this ROM for a couple of days now and I reeaaallly like the theme colors! Just one problem...it is not running very smooth at all. Whenever I scroll from screen to screen, open an app (like opening my contacts or my texts there is a annoyingly long lag. Has anybody else noticed this or is it just me? Is there anything I can do to get this to run smoother?
New to rooting and all that, ran mikg rom first, then wanted to give this one a try. I just can't deal with the lag even tho I like it.
You can try freeing up some more room on the phone, clearing your cache, or downloading set CPU, or all 3
i dont know if im doing it correct, but i got the rom installed, but then it keeps on freezing on me over and over, then itll sometimes restart itself too, and ive been having to take out my batteries just to restart the phone again, what am i doing wrong?
Okay let me rephrase that lol. anyone know of a red theme? I'm looking for something similar to sithdroid for cm7. There's a red theme on xda for kinged shooter and kinged pyramid but it doesn't say it'll work for this Rom. Blue isn't really my thing outside of jeans
Use Go or ADW Launcher, download an icon pack, and a red wallpapaer and have yourself a blast....That's how I make all of mine (other than red)
catladyjane
