[ROM] AC-ROM-Froyo 2.2
Would everyone want stock apps(bloatware) removed?
  • Total voters
  • Poll closed .
No disrespect to all that have worked on themes listed in SGBZ but they are not what I am looking for. How can I post a picture here without using outside site?
Easiest way is to use photobucket. I had to break down and create an account just to post screen shot pics here.
[/IMG]
No disrespect taken,everyone likes different things.Thats the joy of android you can usally find something to your liking.
To post a screenshot without a outside link just attach it to your post,think you can post 3 or 5 pics that way.
[/IMG]
Just posting ideas and what I am talking about. I hope this isn't a prob. Maybe someone can direct me to a theme that fits my taste after seeing these photos
I just updated from AC2.6 to 2.7 - new status icons look great! Things seem to be working ok except for superuser. When I try to run anything that needs su, I get 'The application SuperUser permissions (process com.noshufou.android.su) has stopped unexpectedly...' Further up, someone mention forcing the app to close and retrying - I don't see it running anywhere to kill.
I assume that since part of 2.7 was to revert to an older version of su, I shouldn't just go pull down the latest?
You need to flush the data for SU and you'll be all set.
From the home screen:
Menu > Settings > Applications > Manage applications > Click on the "All" tab > Scroll down to SU and open it and clear the data.
Yep that was it. My apps list was sorted by size so I missed it when I scrolled thru the 'S's. Thanks - great work!
Im on AC Rom 2.6...is that the latest version? Anyone had problems with the main clock not matching the time on the device at the top right? They weren't matching up so i did a fresh install and also..how do I get swype to work on this rom? i have it enabled but still cant get it to work.
2.6 is not the latest.2.7 is.
As for swype if it's installed then long press in a text feild and select to use swype.
I have thoroughly tested netarchy's work and It's AC-ROM dev approved for sure. Play around and see what works best for you but beezy and I have had many convos about kernels and we always come back being impressed by netarchy. Great work from him, much respect from us.
You would also get good results with netarchy. Unless beezy says otherwise. :p
I agree,what i suggest before doing it.
If you have any kind of CPU scaling app remove it before flashing a new kernel.(Setcpu,overclockingwidget,etc) I'm not saying there's anything wrong with these apps,just from testing things several times and with several people it seemed to work out better.So,if you want to check out other kernels.
1)remove app
2)reboot
3)reboot into recovery
4)make nadroid
5)flash kernel.zip
6)reboot-play around with you phone for a little while,then install those apps if you want.
If you use setcpu and you decide you want to play around with higher CPU then stock(998).I highly suggest not checking set on boot.It's set in the rom to default to stock(998) on boot.
wobblefix
